Help Reading Plugs
Every time I let it warm up though, I check each header with a laser thermometer. Cylinder 4 seems to be about 100* lower than the rest. I pulled all the plugs (brand new TR7IXs last week). I'm terrible at reading plugs. Can anyone gather any pertinent information from these before I just play off the temperature difference in cylinder 4 and start ripping on it?
Plugs are arranged in the photos (2-4-6-8) (1-3-5-7).
Last image is plugs 4 (left) and 5 (right).
Any input is appreciated!
Cylinder 3 - have you measured the temperature on this one?
3 and 4 are running richer? By the looks of it, they're the only ones that have any kind of browning on their porcelain body. A cylinder running richer, will have cooler exhaust temperatures. Why they'd be running richer than the rest, I have no idea. Could be a myriad of reasons.
The white porcelains on the rest of the plugs have always had me confused. I posted a similar question months ago - but it's hard to get answers on this. Anyway, I figured they'd all have some level of browning, even without mileage. I figured if the cylinders are firing, they'd brown the porcelain.
Doesn't surprise me that nearly new plugs, running at stoich, are still nice and bright white.
No idea why they'd all be this different with literally zero miles on them. Only change since the car was running great before was OEM to TSP roller rockers and new pushrods. Old rockers were practically leaving the valve tip and having a groove worn into them due to the lift
