timing gear question
Old May 31, 2019 | 08:05 AM
dewchugr's Avatar
Default timing gear question
I had an LH6, but it turned out to need a rebuild so I picked up a LY6 short block. We're using the dampener from the 5.3 instead of the 6.0 tensioner. I don't know what ecu I'm using yet, probably MS3 or Terminator. I'm using a three bolt cam, can I use the timing gear with the 4 raised sections and get the later sensor or do I need to use the gear with the half circle raised section? The front covers are the same, right?
Thanks
Old May 31, 2019 | 08:52 AM
MechMan1's Avatar
The LY6 has the 58x reluctor wheel so you will need the gear with the 4 raised sections unless you were looking to convert to drive by cable. The front cover will work with that engine
Old May 31, 2019 | 09:00 AM
dewchugr's Avatar
Thank you. That's what I thought, but want to be sure before it's all together and in the car.
