106 lsa on LS3
Old Aug 6, 2019 | 03:52 AM
JezzaE's Avatar
https://www.hotrod.com/articles/cams...ted-explained/ This is for a Gen1 small block but they compare the difference in power band between different lobe separation angles and how it effects power, but obviously different engines and cylinder head designs will like different valve timing events, but they do show the difference in idle vacuum between the different cams.
