Intermittent rough running from a mechanical source?
Run this by the mechanics. Have them go into the ECM via HPtuners, or EFILive and turn off the knock sensors. You have plenty of octane in that fuel to resist any harmful detonation. The lead in the fuel can aid in detonation. Perhaps the sensors are picking up detonation and retarding timing? I’m simply thinking out loud here. Not really turning enough rpm to warrant using knock sensors in this application in my opinion...Worth a shot.
What would be the symptoms of a bad can position sensor? Similar to what we’re seeing, I suspect.
In this airplane the engine is mounted backward and there is very little space between the face of the engine and the firewall. So I imagine it gets pretty hot in there, without the usual cooling air blowing over it.
Not hard to imagine the sensor would overheat.
We’ll see come Monday
Jim
it starts out intermittent and gets worse as the fouling increases. Oh and the lead fouling is really hard to see..
Its the same color as most electrodes, but you might see dark gray streaks on the insulator.
My guess is a valve was sticking in its guide when it got hot, resulting in a bent pushrod and misfire
Thanks for all your feedback, guys.
Jim
Glad you got it figured out, and thankful nobody got hurt in attempting to fly with the hurt engine. Very unfortunate that you got your hands on an engine that was hurt and it ended up in an aircraft of all places. Just don’t see LS engines very often that are defective when new.
