do i have enough valve to piston clearance??
Old Jul 21, 2019 | 05:00 PM
1990iroc's Avatar
Default do i have enough valve to piston clearance??
i have an 08 ly6 engine with the ls3 823 heads..the heads have not been milled and still have factory head gaskets..ive deleted the vvt i currently have a tsp stage 2 ls3 cam 229/244 . .629/.615..bout the kit with TSP .660" Dual Spring Kit w/ Integrated One-Piece Seat & Seal, Titanium Retainers, PAC Springs #199-ISSPACPOL660SpringKit..
i want to know if i have enough valve to piston clearance ..and if i can run the stock rockers
intake exhaust
duration .050 229 244
lobe lift .370 .362
valve lift @ 1.7 .629 .615
lobe separation 112
intake center line 109
Old Jul 21, 2019 | 05:16 PM
01CamaroSSTx's Avatar
That is something you really have to measure for but I guess the real question your asking is can I just bolt it up and go.
Old Jul 21, 2019 | 05:37 PM
1990iroc's Avatar
yes i dont want to fly cut...just wondering if anyone has the same setup as mine and if i will be good.
Old Jul 21, 2019 | 05:43 PM
LLLosingit's Avatar
Misread your post, TSP should be able to answer that.
Old Jul 22, 2019 | 03:10 AM
cmysix's Avatar
LS2 stock bottom end, Trick Flow "fast as cast" 220's stock MLS gaskets I'm running a Comp Cams 231/139 113+4 .617/.625, if that helps,
Old Jul 22, 2019 | 12:08 PM
Hodgdon Extreme's Avatar
Please check your PtV clearance! Don't just slide it in and assume it's good because some dude on the internet says it'll be ok.
Old Jul 22, 2019 | 03:34 PM
Ls7colorado's Avatar
that cam is designed to be used without fly cutting, so assuming you use stock thickness gaskets.......... .. .
Old Jul 22, 2019 | 08:30 PM
This...
Old Jul 22, 2019 | 10:24 PM
1990iroc's Avatar
so i called TSP today and they said that i should be fine as long as i dont mill the heads ..and said i can run the stock rockers but to check valve springs every 10-20k miles
