LS7 block question
Old Jul 23, 2019 | 06:49 AM
Orange Juice's Avatar
Default LS7 block question
Car was down on power, leak down test show cylinder 7 is bad. What are my options, can the block be honed or should I just get a new block?
Old Jul 23, 2019 | 07:27 AM
Double06's Avatar
You could try a hone but not a bore. Your machinist will be able to assess situation. The stock LS7 block can not go any more then what you have (GM sleeves very thin and material is just regular iron). I have seen people do .005 over as a clean up. You could also Darton (ductile iron) sleeve the entire block and bore up to 4.185 or just leave it a 4.125.
Old Jul 23, 2019 | 09:42 PM
xBoostx's Avatar
How much power where you making to the tires
Old Jul 23, 2019 | 10:09 PM
It made 500 rw down 50 with more intake. Leak down on #7 dropped 60%.
Old Jul 24, 2019 | 09:27 AM
AgFormula02's Avatar
You can go 4.130 or even 4.135.
Will depend on the machine shop, their skill, and also the true size of the liner.
Contact LME or someone with experience before you let someone ruin a 2500 dollar block
Old Jul 24, 2019 | 11:51 PM
Steve - Race Eng's Avatar
LS1TECH Sponsor
Default Ls7
Make sure cylinder 7 cylinder wall isn't cracked. Is there any coolant in the oil?
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old Jul 25, 2019 | 07:00 AM
Haven't seen any coolant in the oil but have noticed that coolant level does drop. I think getting the blocked sleeved is the better idea. My builder has a shop in Detroit he recommended. I didn't get the name. Tough being in Canada, at least i'm close to a border.
Old Jul 25, 2019 | 02:03 PM
LS1TECH Sponsor
Default Ls7
Sounds like the block may be cracked if the coolant level is dropping. These castings are not easy to weld successfully without experience. I repair these on a continuing basis.
Good luck with this,
Steve
__________________
Steve Demirjian
Oceanside, Ca.
760-630-0450
 Michael S. Palmer
Old Jul 25, 2019 | 02:57 PM
Thanks, wait and see what's what when the motor is out. I'll PM you once I have a better idea what route to go.
