Oil Pumps
Old Aug 7, 2019 | 02:46 PM
ezstriper's Avatar
Default Oil Pumps
Doing a gen IV 6.0 for my avalanche, stock rebuild, loosing the variable valve timing, using a LS2 cam, but hear different opinions on oil pumps..stock low vol. GM, melling stock, melling high pressure, what is a good recomendation, thanks Rob
Old Aug 7, 2019 | 05:27 PM
Smokey B's Avatar
Hi pressure ...
Old Aug 7, 2019 | 07:24 PM
Originally Posted by Smokey B
Hi pressure ...
^^^^^^^This^^^^^^^
Old Aug 7, 2019 | 07:26 PM
The VVT engine your rebuilding has a GM high volume oil pump. It pushes 33% more volume than a standard GM pump. That’s a lot of oil. In comparison, a Melling high volume pump moves 13% more volume than a standard volume Melling pump. Your losing VVT, so you don’t need the volume anymore. Do your research. Call Melling direct. They love to answer questions about this stuff. If it were mine, I’d go with a 10295 Melling, which is 10% more pressure than stock, and standard volume. You’ll get plenty of opinions on this subject.
Old Aug 8, 2019 | 08:25 AM
ezstriper's Avatar
thanks...what I was thinking as well...
