Newb Injector Request
Old Sep 30, 2019 | 08:11 PM
MX763's Avatar
Default Newb Injector Request
My Trailblazer SS toasted a rod bearing so she is getting the old forged 408 treatment. My tuner told me to get OEM LS3 injectors with the spacers and there shouldn't be any problems. Where do you all get your OEM parts like injectors from? The spacers seem to be a dime a dozen and readily available but I am finding a ton of options for OEM injectors. Also, is there a cheaper or more efficient injector to get rather than LS3 injectors and spacers?
TIA!
Old Sep 30, 2019 | 08:28 PM
I’ve bought 3 sets of ls3 (LS7 are same) injectors off of guys on Corvette Forum. They don’t put miles on on those fancy things anyway, but occasionally you’ll find a set with just a couple thousand miles on them.
Old Oct 1, 2019 | 07:48 AM
lazerlemonta's Avatar
If your building a 408 and plan to make any power at all stock LS3 injectors are only good to about 480rwhp on 93 if you use E85 they will be done by 440...... LSA injectors will get you to 560 on 93 and 520 on E85
Old Oct 1, 2019 | 08:02 AM
MX763's Avatar
I read somewhere that the design of LSA injectors causes an uneven atomization in NA LS motors or something along those lines. Is this an issue or is it bs?
Old Oct 1, 2019 | 09:03 AM
Well I personally used the LSA injectors in my bolt on set ups and made 450+ sae with my LS3s in 2 separate builds using them. I had them in my current HCI and made 563 but my duty cycle was at 116% so i went with pantera efi injectors. They have been used successfully and documented numerous times with no issues. They are a cheap alternative for mild builds and excellent data.
