Valve spring recommendations
Old Oct 18, 2019 | 04:28 PM
99blkfrc99's Avatar
Default Valve spring recommendations
Got a G8. Bought it with unknown cam. Want to change valve springs for piece of mind. It currently has singles in it, which is what I'm looking for. Cam not too big, only 415whp. What do you guys recommend for a good single spring? Thanks.
Old Oct 18, 2019 | 04:51 PM
Just about any of our sponsor/vendors have great HD beehive springs on hand. Check WS6store, TSP, Cam Motion, among others.
Old Oct 18, 2019 | 05:03 PM
EMWHolliston's Avatar
I dont see why you would not want to run a dual valve spring. The cost vs the potential damage greatly outweighs in favor of the the dual valve spring.
Old Oct 18, 2019 | 05:57 PM
bortous's Avatar
Agreed.
It's not worth the risk running a single spring
Old Oct 18, 2019 | 06:05 PM
99blkfrc99's Avatar
I hear ya. I've put 30k on it since I got it and have no idea how long before that the cam was put in cause it was a dealer car. I don't know anything about seat pressure, open close pressure etc. that's why I was trying to get a rec. thanks.
Old Oct 18, 2019 | 06:47 PM
bortous's Avatar
Something like a Pac 1207x is a good spring to use for most normal aftermarket hydraulic camshafts.
Seat and open pressures are street friendly and will suit most street driven camshafts.
Old Oct 18, 2019 | 10:04 PM
Darth_V8r's Avatar
Moderator
I would not want to make a recommendation without knowing the cam specs or the valve selection.
Old Oct 18, 2019 | 11:15 PM
bortous's Avatar
It's true.
However I am referring to the majority of street profiles.
Usually about 160lb seat pressure and 425 open pressure
 Michael S. Palmer
Old Oct 19, 2019 | 12:33 PM
JakeFusion's Avatar
Super Hulk Smash
I would think the BTR Platinum kit would work. It works for most hydraulic profiles with stock type valves.
And just because the cam seems to be mild, doesn't mean it has mild lobes. It could be a small duration LSK lobe profile that drives very well and is hard on the valvetrain.
Old Oct 19, 2019 | 01:13 PM
99blkfrc99's Avatar
If I were to guess I would say Vector Mororsports 1.5. It has their pushrods in it, single springs, which come with their kit. I can't find any specs on it tho.
Old Oct 19, 2019 | 01:27 PM
JakeFusion's Avatar
Super Hulk Smash
Not much data on the cam specs. But I think either buying another set of beehives from them or their dual spring kit would be safe.
Old Oct 19, 2019 | 01:37 PM
JakeFusion's Avatar
Super Hulk Smash
Actually, I google searched and found on G8 forum in their cam database... Stage 1.5, 223, 231 .610 .617, 116
Those look like LSL lobes. So, not really mild but easily controllable. I'd go with the BTR Platinums with them.
Old Oct 20, 2019 | 08:36 AM
99blkfrc99's Avatar
Thank you!
