LC9 pushrod/rocker issues and an embarrassing mistake.
The OEM pushrods are all the same length, nominally 7.4". Matching them is not a concern.
Get to the bottom of the noise, get a good book on overhauling the LS, and have at it.
On stock lifters, moving your pushrods to different valves is highly unlikely to affect anything. If your preload moves say .025, that can be a problem. Stock lifters are usually varying by .005.
How is your oil pressure?
Oil pressure is at the lowest 15 psi. That is fully warm. When its ticking, its 40 psi plus because it's cold. I run standard 5w-30.
The pushrods thing did not cause it. Debris in your oil may have from the tensioner going out
