Loctite
Old Nov 3, 2019 | 07:48 AM
fastlt1's Avatar
Default Loctite
When reusing all the original factory fasteners in rebuild, what are you using Loctite on and what color?
Old Nov 3, 2019 | 07:56 AM
Floorman279's Avatar
anything that needs loctite will already have them on it if using new factory fasteners. but nothing wrong with a few dots of blue loctite on anything. except the valve cover and intake bolts, unless u bought new stainless ones that long
Old Nov 3, 2019 | 09:03 AM
fastlt1's Avatar
Just reusing old stuff
Old Nov 3, 2019 | 09:09 AM
so are you wondering what bolts should have loctite on them from the factory then? honestly i think just the head bolts have something on them but whats weird is arent you supposed to retorque the head bolts after a few heat cycles which would then break the seal on the loctite, or is that just with head studs which dont use loctite?
the only thing i would think that loctite could be needed is the long intake bolts but buying the strongest grade of bolt in that length i could
Old Nov 3, 2019 | 09:34 AM
patSS/00's Avatar
Per the 2000 service manual, loctite is only used on the intake manifold, exhaust manifold, and flywheel bolts. It gives a GM part # which according to posts on here is equivalent to blue loctite. For the flywheel bolts it also acts as sealer.
The intake bolts will definitely back out if you don't loctite them.
EDIT: Forgot one: manual says loctite also for the small M8 head bolts.
Old Nov 3, 2019 | 01:43 PM
KCS's Avatar
KCS
Moderator
I use it on the cam gear bolts too
Old Nov 3, 2019 | 01:50 PM
QwkTrip's Avatar
And the bolts that hold the oil pump pickup tube.
I'm not sure Loctite helps anything for exhaust manifolds because of the heat. I once had a little screw that somebody installed with "red" Loctite and it was never coming apart in a million years. I put it in an oven for a little bit and the Loctite released and I got the little screw out.
