Cam sensor is hitting the timing gear!
Old Nov 7, 2019 | 06:17 PM
Micah Moorhouse's Avatar
Default Cam sensor is hitting the timing gear!
Just had the motor rebuilt with afm delete and vvt delete. About to put it back in and notice the cam sensor will not go all they way in because it hits the timing gear. Help please!
Old Nov 7, 2019 | 06:19 PM
What engine? What exactly did you change over?
Old Nov 7, 2019 | 06:23 PM
Gen IV 5.3 out of a truck I had the motor rebuilt. I did the afm delete , vvt delete , 3 bolt cam. Everything else is still stock!
Old Nov 7, 2019 | 06:26 PM
Which cam sprocket did you use?
Old Nov 7, 2019 | 06:41 PM
Unfortunately I dont know until tomorrow! I have to call the guy that built it for me. I can see the numbers o. The gear through the sensor hole. I thought about trying reference them to see what gear it is if this guy doesn't have an idea.
Old Nov 7, 2019 | 06:44 PM
I already said something to him and he thought maybe I needed a different sensor. I have the same sensor that's is in the kits and nobody else seems to have an issue. Just looking for some ideas.
Old Nov 8, 2019 | 02:56 PM
Cam sensors are the same.
Old Apr 11, 2022 | 02:47 PM
Jbo42024's Avatar
just wanted to know what ended up being your issue cause I just ran into same problem after my afm/dod delete
Old Apr 11, 2022 | 03:52 PM
He hasn't been here since his last post above.
