Lifter Question
Old Nov 11, 2019 | 10:00 PM
LewisL230's Avatar
Default Lifter Question
I’m in the planning stages of a budget weekend warrior N/A LC9 build. It’s the usually carb swap with a Summit 8702 cam and BTR .660” Platinum dual springs. I’ve done some research and can’t seem to find a definitive answer on which lifters would be right for this build. Obviously with the DOD delete I’ll have to have new lifters. I was looking at the Summit LS7 lifters or just GM replacement LS2 lifters. Am I on the right track or am I way off course. I don’t want to spend a ton on aftermarket lifters. I’m not going to be turning this motor to the moon, maybe 6500 at the most.
Old Nov 11, 2019 | 11:49 PM
bortous's Avatar
Depends also what springs you are going to be using.
LS7 lifters would be the minimum I would use.
If you do go for a better quality aftermarket lifter I recommend the Morel street series tie bar lifter.
It's more robust and designed to be revved to 6500rpm.
I don't think they are much more than the LS7 lifters and you have the added security of the tie bars.
I had them on my engine once and they were very quiet too.
No ticking.
Old Nov 11, 2019 | 11:53 PM
Just a heads up, the "GM replacement LS2 lifters" are actually LS7 lifters, as they are now the default replacement GM LS lifter.
Old Nov 12, 2019 | 12:09 AM
bortous's Avatar
Oh ok I didn't know that G.
Thanks for the heads up.
Old Nov 12, 2019 | 12:20 AM
LewisL230's Avatar
Thanks for the info, I didn’t realize that. This engine is going to be as budget as I can get so I will probably go with the ls7s. Thanks for the info.
Old Nov 12, 2019 | 07:57 AM
psicko's Avatar
That cam is a little big for a little 5.3L at 6500 rpm, isn't it? I would go with stock replacement lifters and get a cam that has about 10 degrees less on the intake and exhaust.
Old Nov 12, 2019 | 09:07 AM
Jimbo1367's Avatar
Default Lifters
The magazines use Comp Cams LS replacement lifteRs a lot of the time. Those are cheap. Must be worth further research
Jim
Old Nov 12, 2019 | 12:54 PM
Jim
That's because Comp comps them the lifters. I would use GM lifters. Comp has **** the bed a couple times too often to suit me.
 Michael S. Palmer
