PSA -- Learn The Math!
I was attempting to hit a certain compression ratio via domed pistons. Vendor unimportant. The catalog was showing a compression ratio that was 0.7 lower than I calculated from the catalog information. So I kept scouring the internet for more info on these pistons. I found a ten year old tech bulletin that agreed with my calcs and disagreed with the catalog values. I then checked vendor sites, all of which were listed on the right. Again, vendor unimportant. The catalog values, which I suspected were incorrect, had been copied into every reseller's technical details. All of them agreed with the catalog.
So, at this point, I thought I must be insane, so I called the manufacturer and got to their tech department. He redid the calcs with me on the phone and confirmed I was right and the tech bulletin was right, and all the catalogs and websites were off by 0.7. He then told me he estimated x-hundred catalog entries were incorrect.
So, bottom line -- if you plan to spend any time and money on this hobby, learn the math before you just buy parts and slap them together.
Also, make sure you know how they are calculating the compression. Wiseco and Diamond both tell you the deck height and gasket thickness. So they are at least close. But you need to know those for your motor so you'll know your actual CR.
JE pistons are .015 down in the hole. I used the simulator and the thing kept reading wrong. So I played with where the piston was at to the deck... .So I call JE the next day and asked so where's the piston set in the bore for you guys calculation for compression?
.015 i replied that it sure would be nice if you guys listed this...
The guy on the tech line doesn't know what the true deck height is on your block either, so they usually go off of stock spec of 9.240/9.230".
I learned the math and made spreadsheets for personal use. Everything from calculating displacement to average airspeed in the port and even inertia loads on the piston. It's all posted online somewhere.
Keep your punk as smart remarks
called everyone and it's all good. Cost of switch $80 total.
Thanks sicko...
On my Wiseco pistons, they are actually configured for a Zero Deck at 9.235" but again, Wiseco actually lists it in their catalog correctly so you have an idea of what you're getting before you buy it.
Thanks sicko...
Then do your math, get the parts in hand, install crank, one rod/piston, and measure the piston dome or dish volume. Still will be some math. But you will get true CR.
