Our Summit Pro LS pistons and rods are up to the task of a 250-275 hp shot. The pistons are modern 2618 forgings designed for boost and nitrous. They have thick ring lands for durability. The rods are top-notch 4340 H-beams precision-honed in the USA to +/- .0001". The rods come out of the box with ARP 2000 7/16 rod bolts with 200,000 psi tensile strength. Those are typically an upgrade option for other rod manufacturers. Our piston and rod kits come with a premium ring pack. They include steel top rings designed for boost and nitrous. They also include Napier-hook second rings for maximum strength and oil control.
You could increase compression to 11:1 with stock 70cc heads using our 2cc dome piston. That would be the
SUM-PR36L0652 piston/rod combo for the stock bore. If you needed to go .005" over we have the
SUM-PR36L0702.
If you think it's possible you will do a 300+ shot in the future, it would be a good idea to do upgraded pins. Those would be Wiseco
WIS-S718.
