High compression & Oem stock block
Weight penalty eats it back up or cam the aluminum block for more Rpm to make up the hp difference.
its a old known thing that I've heard and read. Ask any Professional engine builder that's making Hp...
62 your on point reason for having the older and newer model 4l80 both gotten for under $700.oo one came with the entire engine and harness.
How's that? I asked it Already from a Professional 😂 or read it.. just ramblings..
https://www.yellowbullet.com/threads...block.1714098/
http://www.performanceracing.com/mag..._aluminum.html
I will never use an iron block due to the weight and heat penalty.
A dart aluminium block is quite strong from what I read.
Even the LS9 block is too.
Larry Meaux
a back-to-back Dyno test on SBC
cast-iron Bowtie Block -vs- alum Block
everything exactly the same, just blocks were swapped
there was 30 HP difference at 600 rpm/sec
another back-to-back Big Block Chevy test = approx 40 HP
another back-to-back SS Hemi test on Cylinder Heads only
with cast-iron -vs- aluminum = 12 HP more w/cast-iron
same flow numbers + port vol CC's
the above were actual Dyno tests,
for theoretical HP/TQ differences between alum -vs- iron Blocks
by using FlowBench CFM Numbers -vs- what HP the different
block materials made on the Dyno =>
the results were=> for the same Flow CFM numbers,
i have yet to see an aluminum block engine make
the same HP/TQ that the cast-iron Block engine makes.
so far in all my Data,
the cast-iron Block always 100.0 % PerCent of time
makes more HP/TQ than an aluminum block
the last Dyno test was a recently as 2 months ago
with Brodix SBC and SB2.2 Heads
again the aluminum Block did not make as much HP
as the Flow Numbers suggested, about exactly the 30 HP
i found in those back-to-back Dyno test i did about 10 years ago
with another manufacturer's alum block -vs- Bowtie cast-iron.
to date, i have never seen an aluminum block make
1-the same exact power/torque as cast-iron
2-make more HP/TQ than cast-iron
it has always been LESS so far....
Older post, but aluminum blocks have gotten better with adding more meat in certain places to help with movement.
