*OFFICIAL* Smokey’s high as a kite random rambling thoughts thread!*****
could have sworn he hacked your account to post that. Roflmao
good one Anybody else out there have a 416ci with LS3 heads thats pretty impressive?
Or the fact that a OTB aftermarket Ls3 head just doesn't have the area to be a faster Version of....reason u seen the results u did @ Lsfest.....with a stroker you need a certain amount of Area and talking RPM & HP.
Add more $, by this time u darn near $4k+ in with just a low laying Ls3 head.
It's all over the forums.
Even here in Australia.
Huge discussions especially in the early days.
I guess my opinion is the high end cathedrals from Mamo make some serious power and torque throughout the entire power band.
I think in the top end and beyond 7000rpm the square ports would perform better.
PRC did it with, what a Store owned Car and or Ls7 heads BTW they where used to get more compression as the ls7 has better P 2 V clearance? That's what kills me ..you see one thing when the maker or porter does it ...then it gets to the consumer or customer and BAM! PoP! BOOM!
Flat Line! I haven't seen Nothing special about nothing seen Ls7 or 3 for a Dyno or ET that's, that much better or faster to constitute buying some of the stuff seen. Guys are doing times right now that we're done yrs ago with less technology.. I don't believe or buy the hype. Now if we are talking 1000+ HP maybe better casting but 1 for dollar..
With a good porter & good short block.....anyone can be fast not just the wallet Warriors and hell most of them ain't fast either per dollar vs ET.
Everyone that has his heads never complain.
They are known for having explosive torque and hp at any rpm.
Darth had these on his ls1 and they were mental.
At the track, I'm not sure how they do.
I know the TFS 245cc head is a notorious 1/4 mile champion with a lot of guys going quick using these.
One of Brain Tooley's favourites.
Pat G seems to really like this head as well as the ported GM LS7 heads also.
I don't know much about the MAST cathedrals.
I didn't even know they make them till you mentioned it.
If I was going Cathedral I would probably go with Mamo due to the fact that he is great to deal with.
I could get the intake either a FAST 102 or an MSD through him and he will also port and match it as well as set up the heads with his springs and rockers.
I know everything will be set up right.
I would most likely use a cam motion LLSR grind too.
I have had a couple of conversations with him on the phone about this and he said for my engine the 235cc head would work best.
I won't touch any aftermarket LS3 head.
They have been proven to not really be much better than the stock head.
98_ws6_m6 coasted to mid nines on mamo heads when is inlet pipe blew off after the eighth. Something like 9.6@117.
Don't get me wrong, i know track slips are street cred, but do at least consider the possibility that it has more to do with his typical customer than his product. And FWIW, every AFR LS head you've ever seen at the track is also his.
There's always going to be someone at the track with a 6000rpm converter and gutted car with 4.56 gears and suspension setup for all out ET to make whatever parts they have look better than someone elses on lesser setup cars. Which is why I tend to focus more on the mph a car runs and how much improvement gained over their previous setup. I'm sure if Tony really wanted to, him or one of his customers could have some 1/4 mile times out there that are up there with anyone elses.
