Is this to much tick or normal
Old Jan 10, 2020 | 12:54 PM
Dr1rrrr's Avatar
Default Is this to much tick or normal
I know this topic has been beaten like a Dead horse but I'm just worried. It's a 2013 Caprice with a sloppy stage 2 cam (.585/.585 228/230), summit racing ls7 lifters, summit racing 7.400 hardend pushrods, stock rockers, and comp cams 26918 valve springs. Here is a video of it running.
https://youtu.be/QbzEg4WVxDg
Old Jan 10, 2020 | 01:36 PM
98CayenneT/A's Avatar
Old Jan 10, 2020 | 02:12 PM
Dr1rrrr's Avatar
Thanks for uploading it I couldn't figure out how to make it show up right
Old Jan 10, 2020 | 05:44 PM
Tramminc's Avatar
Headers amplify the sound.
Old Jan 10, 2020 | 07:26 PM
wannafbody's Avatar
Mine sounds pretty similar.
Old Jan 10, 2020 | 08:40 PM
dreadpirateroberts's Avatar
I think that's pretty typical.
Old Jan 10, 2020 | 08:49 PM
Dr1rrrr's Avatar
This car has stock manifolds and stock exhaust
Old Jan 11, 2020 | 09:05 AM
Jimbo1367's Avatar
I couldn’t hear anything, but it’s noisy here at work.
Old Jan 12, 2020 | 06:05 PM
Dr1rrrr's Avatar
The tick also increases as rpm increases I would assume that's normal too but I'm not sure
Old Jan 12, 2020 | 06:08 PM
Dr1rrrr's Avatar
Old Jan 13, 2020 | 12:11 AM
it sounds like a cammed LS. it's actually kinda quiet if you ask me. stick a fast and headers on there and you will be like WUT.
usually a loud exhaust and the choppy idle will drown out the valve train, noise, though, unless you stick your face right up by the engine.
Old Jan 13, 2020 | 09:31 AM
Dr1rrrr's Avatar
I plan on upgrading my exhaust to be louder so I guess that will be the fix!
Old Jan 21, 2020 | 08:39 PM
01CamaroSSTx's Avatar
Typical valve train noise your hearing.
Old Mar 6, 2020 | 11:11 PM
Glenn Klippel's Avatar
STOCK ROCKERS???? Hell no......
bro you did everything else right but you some how left out upgraded rockers, you DEFINITELY need to upgrade them. I'm running basically the same stuff you have in ya rig, but I have comp push rods not summit racing and mine doesn't sound like yours, t it's a lil noisy but nothing to worry about especially when I'm doing the bottom end at some stage this year so will freshen up everything else or replace if Need be
Old Mar 6, 2020 | 11:16 PM
99 Black Bird T/A's Avatar
Sounds pretty typical to me.
Old Mar 7, 2020 | 09:41 PM
RonSSNova's Avatar
Exactly. The fast intake acts like a speaker and amp amplifying the valve train. No one ever mentions this.
OP, that’s just the normal LS noise.
