PEC Shaft rockers
Old Jan 16, 2020 | 08:21 PM
Use ur name's Avatar
Default PEC Shaft rockers
Has anyone used these? I'm wanting to go with a solid roller & need some way to adjust the valves.
https://www.summitracing.com/tx/part...make/chevrolet
Old Jan 17, 2020 | 02:11 AM
Jontall's Avatar
Chinese junk.
Old Jan 17, 2020 | 09:06 AM
Jimbo1367's Avatar
I wouldn’t put them in a motor I planned on using
Old Jan 17, 2020 | 03:37 PM
Johnnystock's Avatar
There is some HS or YT adj rockers around 850-900$, if you dont wanna shell Jesel or T&D money...
Old Jan 17, 2020 | 04:19 PM
Adjusting the valves is not necessary with a solid roller. Get your pushrod lengths to within a few thou of your target lash, and use lash caps to take up the necessary slack. It’s been done on here a couple times that I’m aware of (Thunderstruck and Darth did it). It will take a lot, repeat, a lot of set up time, but once you get it right, it’s right. Maintenance free valvetrain. If lash opens up, or vise versa, with this setup, you have a problem. This is the setup that all modern NASCAR Cup teams are using. It’s dependable and has less moving parts. I can see me going this way in the near future.
