Detonation under no load
#8 is a corner and corners are where lack of piston to head clearance will show its ugly head first. If you see carbon missing on both the major and minor thrust, the piston can hit the head enough to collapse a piston’s skirt. Then the problem quickly exaggerates itself as the piston skirt collapses more and hits the head harder with every revolution. We’ve seen piston skirts collapsed equally across all 8 cylinders as much as .030” after piston to head contact. Crazy stuff. Not saying it’s your issue, but food for thought. .036 is our bogey for tight piston to head clearance accounting for head gasket thickness.
Thank you for the response, believe me, I was confused how detonation would happen under no load. I had the engine torn down by my engine builder and all the bearings look great, there is no scoring or marks on the head or piston. The engine builder said he sees detonation marks on the top ring lands of 2 pistons, unsure which cylinder he found the second issue. Maybe we are missing something, but there is nothing obvious in the engine.
