How to convert LS3 to LS7 style dry sump
Old Mar 3, 2020 | 04:30 PM
Bee Jay's Avatar
Default How to convert LS3 to LS7 style dry sump
I have a Blueprint Engines stroker 427 LS3 in my 1979 C3 Corvette. I also have the LS7 oil pan and oil tank and lines from the failed engine I replaced. I know that the C6 Corvette Grand Sport, six-speed standard had a 6.2 liter dry sump engine. What would it take to convert my 427 LS3 to dry sump? Do I have to replace the melling oil pump? Crank? Can I use my LS7 oil pan and oil tank? Has this been done? Just curious, but if it can be done without changing the crank, I might be up for it. The 79 is used mostly for autocross and drives to coffee and donut gatherings.
Old Mar 3, 2020 | 04:34 PM
jayyyw's Avatar
dry sump crank, dry sump oil pump, dry sump front cover, dry sump oil pan, dry sump tank, lines, oil dip stick plug.
Old Mar 3, 2020 | 04:37 PM
spanks13's Avatar
You'd have to change to a long snout crank to use the factory stuff.
Also front cover, and oil pump.
Old Mar 3, 2020 | 04:57 PM
Bee Jay's Avatar
OK, thanks, bad idea. I'll use my old Moroso acusump accumulator.
Bee Jay
