421 stroker
Old Jul 30, 2020 | 12:53 PM
ssdungeon's Avatar
Default 421 stroker
For iron block lq4 or lq9
TSP and others have kits.
has anyone had any experience with the 421 kit?
I understand it will cause probably increased heat because of the long stroke.
definitely not good for boost or massive nitrous hits..
For NA revving no hogher than 6500 rpm every now and then ...
would it last ok?
Please share your insight.
Old Jul 30, 2020 | 12:59 PM
bortous's Avatar
What block?
LS3?
Old Jul 30, 2020 | 01:07 PM
ssdungeon's Avatar
Originally Posted by bortous
What block?
LS3?
lq4 or lq9 iron
Old Jul 30, 2020 | 01:10 PM
bortous's Avatar
Originally Posted by ssdungeon
lq4 or lq9 iron
Can you overbore this block to 4.060 being iron?
The gen 4 LS2 can only go up to 4.030.
Old Jul 30, 2020 | 01:33 PM
KCS's Avatar
KCS
Moderator
Yes, you can, but he’s probably talking about a 4.030” x 4.125” rotating assembly.
Old Jul 30, 2020 | 01:52 PM
bortous's Avatar
Ok cool.
Let's see what stroke and bore the OP is planning on using.
Old Jul 30, 2020 | 02:38 PM
ssdungeon's Avatar
that's correct.
The bore 030 is fine for the iron 6.0 im sure of that.. 7plus years i had that with a 350 shot revving to 7000 rpm sold it runnimg.
The longer stroke is the main question area I think. There mY be other things to consider so if anyone has insight let me know before I pull the trigger.
Old Jul 30, 2020 | 03:16 PM
DavidBoren's Avatar
How much of the piston is still in the cylinder at BDC? Don't the iron blocks have notoriously short cylinders?
Old Jul 30, 2020 | 04:34 PM
64post's Avatar
I did a 425 ci using a LQ block 4.065x4.100 only because I had the 4.100 crank laying around. I would suggest no more stroke than 4.00 If you still have a choice. The skirt of the piston on a 4.100 stroke hangs out a lot abdc.
Old Jul 30, 2020 | 05:21 PM
BigDaddy97's Avatar
I ran a LQ4 based 421 stroker with 821 heads in my drag truck for a couple years. Ran 10.20's shifting at 7200.
Old Jul 30, 2020 | 08:10 PM
ssdungeon's Avatar
when it failed was it from a piston dropping too far?
Old Jul 30, 2020 | 08:42 PM
BigDaddy97's Avatar
No sir. I had a shop change my heads and cam, and they didn't verify valve to piston clearance so a valve kissed the piston and destroyed it.
Old Jul 31, 2020 | 04:52 AM
Jimbo1367's Avatar
WTF? lol. I hope you went after them. They should of known to check. With that said, I would of made sure they knew they had to check it.
Old Jul 31, 2020 | 10:33 AM
DavidBoren's Avatar
What shop worth its salt changes the heads AND cam without checking PTV clearance? Seriously, who-the-f!ck does that?
PTV clearance should be checked even if you only change the heads OR the cam... definitely if you change both. Measure for pushrods. Check the rockers contact patch and geometry.
Half-assed nonsense, somebody deserves to stub their toe every day for the rest of their pathetic natural life...
Old Aug 1, 2020 | 12:50 PM
KCS's Avatar
KCS
Moderator
The longer stroke is the main question area I think. There may be other things to consider so if anyone has insight let me know before I pull the trigger.
I have a 4.250" crank in my 6.0L iron block so I wouldn't even hesitate to run a 4.030" x 4.125" combo.
