Weird valve spring question
Old Jul 31, 2020 | 02:08 AM
Dr1rrrr's Avatar
Default Weird valve spring question
If you had a cam with different lift specs for intake and exhaust could you run 2 different pressures of valve spring?
Old Jul 31, 2020 | 04:39 AM
Jimbo1367's Avatar
You would normally run the higher pressure springs. I’ve never heard of anyone running setting per intake/exhaust
Old Jul 31, 2020 | 06:24 AM
Darth_V8r's Avatar
Moderator
I have treated spring rates based more on ramp rates than gross lift. Never really heard of anyone splitting kits, but I am sure it happens.
When exhaust lift is lower, typically say .020, not enough difference to matter.
Old Jul 31, 2020 | 07:46 AM
TurboBuick6's Avatar
Normally you will not see this until you enter the Max Effort very high RPM arena. Otherwise same springs all across.
Old Jul 31, 2020 | 11:50 AM
Dr1rrrr's Avatar
Ok thanks guys I was just kinda curious if it was possible
Old Jul 31, 2020 | 03:39 PM
RB04Av's Avatar
Definitely possible; definitely not the usual way.
