Heads for new 468
Old Aug 11, 2020 | 01:14 PM
  #41
BigDaddy97's Avatar
Originally Posted by carbuff
Just curious, are those lift numbers for 1.8:1 or 1.7:1 rockers? That's less lift than the cam I got from Tony which has lower duration, but mine is at 1.8:1 ratio (0.720" lift).
That's using 1.82 roller rockers from tsp.
Old Aug 11, 2020 | 01:42 PM
  #42
AINT SKEERED's Avatar
his is hydraulic still. You are solid correct?
Old Aug 11, 2020 | 02:41 PM
  #43
carbuff's Avatar
Ah, you are correct... Thanx for clarifying.
Old Aug 11, 2020 | 04:34 PM
  #44
BigDaddy97's Avatar
Tony said that's as much lift as he would reccomend on a hydraulic cam with the valves I'm using. Said I needed titanium valves to get the weight down if I wanted more lift.
