Valve Stem Seals on LS2
Old Aug 22, 2020 | 07:58 AM
20107847's Avatar
Default Valve Stem Seals on LS2
Hi,
I need to do the stem seals on my LS2 and want to ensure I order the correct seals. The seals were replace by the previous owner 2 years / 2000 miles ago. I see on summit racing there are possible two different types. I have 243 heads, does this narrow my choice down?
just want to ensure I get the correct ones and the best available as I don’t want to be having to change again.
Cheers Richard
Old Aug 22, 2020 | 08:47 AM
rkupon1's Avatar
Do you have a cam? Or any other mods? 243 heads are great, if your going in, maybe you can do a btr spring kit while your in there.
Old Aug 22, 2020 | 10:26 AM
20107847's Avatar
Thanks Rkupon1.
Everything is standard GM. I want to resolve my blue smoke issue before spending anymore on the engine incase the stem seals don’t solve my issue.
Cheers
Richard
Old Aug 22, 2020 | 04:17 PM
20107847's Avatar
Just go buy some Felpro valve stem seals for a 98-02 Camaro at your local parts store and you'll get the right ones. The black ones are for the intake and brown ones for exhaust...
Thanks 01CamaroSSTx
I live in the UK so parts for LS engines are not as readily available. Is it the top hat seals that incorporate to valve seat as per attached picture that I need?
thanks
thanks Richard
Old Aug 22, 2020 | 04:19 PM
RB04Av's Avatar
Yup, those are a typical replacement seal. Come in some gaskets sets, can't remember what brand. They go over the guide, then the spring goes on top of them.
Old Aug 23, 2020 | 01:47 AM
20107847's Avatar
Thanks Bud.
