High compression l77 for 91/e85
Old Sep 16, 2020 | 06:21 PM
Sebastian Draeger's Avatar
Default High compression l77 for 91/e85
Hey folks, this is my first LS build and would value your insight on my idea for a build. I have a 2014 caprice that I plan on being a daily driver that puts a smile on my face. The standard when searching goes intake, cam, headers, boost. I would like to go a little different route and go N/A with a factoryish appearance.
My idea: factory bore high static compression dome pistons with a lopey/overlap cam that gets dynamic compression where it needs to be and keep the peak under 7k where the ls3 valve train can keep up. Lt1 exhaust manifolds to factory camaro exhaust bits.
Stock pistons are 0cc flattop, heads are 70cc combustion chamber. Ideally I'd like to hone what I have and put new pistons on my existing con rods with arp hardware.
There has to be a reason I'm not finding others not doing this... what am I missing?
Old Sep 17, 2020 | 12:34 AM
64post's Avatar
E85 for a non flex fuel vehicle is a big commitment, you’ll need fuel lines and fuel pump that is compatible, 30% bigger injectors than you would use otherwise. You can carefully run 11.6 static on 91 and 12:1 on 93, how much more static compression would you need?
Old Sep 17, 2020 | 01:59 AM
The caprice is flexfuel otherwise it wouldnt be on my radar. Thinking a compromise between a 91 tune with retarded timing and a e85 tune that rips... but I have no experience with e85 so input is appreciated
Old Sep 17, 2020 | 02:48 PM
low2001gmc's Avatar
MASS seller approved
Consider Wiseco Pro Tru Forged Small Dome Pistons. About $450 only.
Old Sep 18, 2020 | 01:30 PM
Labsforever's Avatar
Most aftermarket pistons are designed to use aftermarket rods so the wrist pins are different so be careful what you purchase
