Heads back from machine shop. Oxidation?
Old Nov 12, 2020 | 07:18 AM
mchicia1's Avatar
Default Heads back from machine shop. Oxidation?
I just got my heads back from the machine shop. Immediately I noticed little white marks all over the heads. The machinist assured me this was ok and would not affect sealing. I have had my heads cleaned and milled a few times and never noticed marks like this. It makes me think a caustic substance was used and it made the aluminum react. I gently used a white roloc disk on a non gasket area and it does come off, but I want to make sure these are not ruined before I bolt them on. Thoughts?
Old Nov 12, 2020 | 09:12 AM
WE TODD DID's Avatar
It’s probably a type of detergent that was used to clean them. They’ll be fine as long as you don’t use the roloc disk on them. Wipe them with acetone and put them on.
Old Nov 12, 2020 | 09:27 AM
mchicia1's Avatar
Ok thank you, I will run em.
