Help
Old Feb 8, 2021 | 07:17 PM
84am's Avatar
Default Help
I have a manual 2001 camaro I just put on 92mm fast intake ptm 92mm tb fast 36lbs injectors tick torquemax stage 3 cam prc 225 heads ftp 98 air lid 85mm maf and tune by frost pcm (mail order) when I put it all together now having running issues. Run for short time cut off, no power sounded good then start missing. Scanned it came back with 351,352,355,356,357 and 358 codes. What could I have hooked up wrong? Also new pushrods measured properly. Any help would be greatly appreciated!
Old Feb 8, 2021 | 07:58 PM
Corona's Avatar
Quick Google search
https://ls1tech.com/forums/pcm-diagn...351-p0358.html
Old Feb 8, 2021 | 08:07 PM
Corona's Avatar
Even better search Results 👍
At the bottom of the page is all the codes your asking about 😉
https://repairpal.com/obd-ii-code-p0352
Old Feb 8, 2021 | 09:04 PM
84am's Avatar
Thanks man
