Lsx454
$2k+ for the block and around $1000+ for machine work.
https://www.youtube.com/user/redbaronprodutions/videos
Size (Lives) Matter 🤣
Rpm (being) Needed and the amount of Tq needed is generally the best way to go about things
Your car/truck weight + gear/trans are a Dead giveaway and it's Usage 😉
https://youtu.be/rLeXbgcORsY
https://ls1tech.com/forums/appearanc...on-lsx454.html
I would not call his car underwhelming but hard to judge from a highway roll-on. It is a 9 second car that doesn't appear to be a flyweight running 6.20's in the 1/8.
For a drop in and go crate engine the LSX454 is a pretty good piece. It can be better with some massaging but all that's really needed is a cam and intake swap for 700hp. Rated at low 600's with a stock ls7 intake, stock ls7 throttle body, and a 236* intake lobe peaking at only 6200 rpm. Put an MSD intake or single plane and something like a 250/266 on 113-114 cam in it and it'd fly on pump gas. If you don't mind taking the heads off then clip the heads to 12:1 compression for 93 octane and let it rip. The weight is the biggest concern...well, and I personally hate the orange paint lol.
If you want ID 2000 or 2600 or whatever they sell go buy them and be happy, I don't care as you aren't spending my money. When people offer me their cash/credit card to build a car I try to get them the biggest bang for the buck. Some guys just want expensive parts so they can brag at cars and coffee, that's not my scene.
I went from a LS2 w/LS3 heads Maggie 1900 to an LSX454, it made more torque, almost same power, and was faster. Had ZERO issue turning 28x10.5/15's to smoke! I had a TH400 with 3.7 gear behind it. I did an SD tune with an LS7 Vic Jr on top. The LSX454 made a good bit more power than my MAST 416, fancy heads, higher compression engine did that cost about the same all said and done...
All Different engine builds Same 3800 lbs car. Blower Helped with the Weight vs the 416 having less Tq, the 454 Helped with tq. IDK if the 454 had SC or Turbo TQ but the added .125 crank stroke Helped. Besides the bigger Bore.
That said, the Guys asking for SC Ls3 numbers..
650+ fwhp & 600 ftlbs of TQ.
That said, 650fwhp and 600lb/ft is pretty easy to achieve by any means, that's only 555whp/510wtq. I've seen well built SBE NA LS3's close in on 500whp. In my car 450hp ran 11.3, 600hp ran 10.3 if that helps the computation at all.
Then went to mamo ls7 heads and msd intake 255/269 solid roller cam and it makes 675rwhp, itll light up the street tyres at 70mph. I drive it every day, tow big loads, ill spin it to 7400rpm every time i get in it
a supercharged ls3 weighs more than the lsx once all add ons are done... i really didnt notice much difference with the extra weight in my car
When i pulled the engine down for upgrade i did notice the piston skirts had a bit of wear but nothing id really worry about plus i dont think the builder specced pistons correctly..
Im happy i built mine and id do it again if going NA
https://www.gmperformancemotor.com/parts/19417353.html
One guy on here once said, GM builds the best motors. I totally get that. If the motor meets your goals, sure is a no brainer
If one more builder wasted my time on the phone, i was ordering the 454lsx or the 570hp wet sump LS7 n throwing my intake on it. I would have been driving my car already n lovn it. But I no doubt made a mountain out of a mole hill n went full custom...again...
At some point, you have to decide what you really want!
