440” Ls7 nitrous build
Old May 21, 2021 | 08:16 AM
  #41
HighspeedLean's Avatar
What size were the dyno headers used? I see at least one step. Also a single stage external oil pump with a stock front timing cover? Cam 280/305-117-ish?
Old May 21, 2021 | 08:20 AM
  #42
WE TODD DID's Avatar
Originally Posted by TTur1996
My God the crazy *** torque comes in and just stays, not to mention the HP, Wow, and that's with a nitrous cam. Would love to see from 5 to 6000rpm. How much spray is going into that torque monster? I smell some 7 second time slips. Goes without saying because everyone already knows, but I will say it anyway. You definitely know your ****. Great Job
All of it 😎
Old May 21, 2021 | 08:22 AM
  #43
They are 2”-2-1/8” headers. This block has no provisions for an oil pump and has to be used with an external pump. Yep, ish on that cam.
Old May 21, 2021 | 09:27 AM
  #44
Corona's Avatar
Now You get the Your a great builder.... What about all the other stuff.
Lmao..
BTW: Hello High Speed Lean...👍
Old May 21, 2021 | 10:38 AM
  #45
Be interesting to see the power difference between the dyno headers and the ones going to be used. Production car front clip?
Must have some lift to prevent choke to get the fill up with that little (?) compression. Nice work on the CID. 1250+cfm Dominator carb?
Old May 21, 2021 | 10:41 AM
  #46
Hey, how's it going!
Old May 21, 2021 | 10:54 AM
  #47
95sscamaro's Avatar
Without going into great detail, I did some plenum mods and got the runner sizing correct. I know that's vague, but that's the best that I can do with that. Depending on the severity, I'll either weld or epoxy when needed. Generally, if there is a lot of material that needs to be added, I use epoxy. If it's a touch up or small area, I'll weld it.
Would you be willing to mod another intake? Please pm me, i have some questions.
Old May 21, 2021 | 12:11 PM
  #48
Corona's Avatar
Good .... I know you don't post Much just saying Hi.
Old May 21, 2021 | 02:36 PM
  #49
Bill00Formula's Avatar
Wow that's crazy. Congrats! Makes my 427 look like a piece of crap.
Since those heads came out, I have always see negative things about them on the forums. I know Tony Mamo uses them but I assume he uses a porters version.
Old May 21, 2021 | 03:20 PM
  #50
It's easy to blame something when you don't know how to utilize it... When someone slaps a bunch of **** together, gets a cam from this guy, heads from that guy, intake from another guy, you usually end up with a bunch of mis-matched stuff. Ideally the system needs to be designed as a whole.
If my heads are lacking in one area, I can compensate for that in another area. So on and so forth.
Old May 21, 2021 | 03:53 PM
  #51
01CamaroSSTx's Avatar
That's a heavy hitter for sure and I'm curios to know what it makes on the fuel injection setup.
Old May 21, 2021 | 04:25 PM
  #52
Corona's Avatar
https://ls1tech.com/forums/generatio...l#post20328493
Old May 21, 2021 | 05:42 PM
  #53
With the correct components and guy tuning it, it should be pretty close. But with the injectors where they are, it’ll be down a bit from the carb.
Old May 21, 2021 | 09:42 PM
  #54
Truth right there. I’ve seen the TFS castings called “BS HEADS” more times than I can count. I just laugh...
Old May 22, 2021 | 08:32 AM
  #55
Corona's Avatar
It's not a Bad Head, Just Doesn't have the Beef to be considered a Race head.
2nd Covid shot 🤧🤢
Old May 22, 2021 | 09:11 AM
  #56
If he builds the headers that I want him to, it "should" make some more power. But since it won't be run without nitrous, it's a moot point. It's about a 1300 cfm Dale Cubic carb.
Old May 22, 2021 | 09:14 PM
  #57
TTur1996's Avatar
All of it 😎
Lmfao. Thought thats what you might say. But what the hell, I took a shot.
Old May 23, 2021 | 08:39 AM
  #58
rkupon1's Avatar
Care to elaborate on the headers?
Old May 23, 2021 | 10:14 AM
  #59
I would like to see a 2”-2.125”-2.250” stepped header for this deal.
Old May 23, 2021 | 10:54 AM
  #60
Darth_V8r's Avatar
Moderator
Me too, but I doubt i'd want to pay for them. I was running numbers on mine, and pipemax says i'd benefit going to 2.25 primaries, but I'd need a chassis swap for that to work. The way yours is running, you'd benefit more than i would.
