L76 Cam for Jimmy
Old Oct 27, 2021 | 04:42 PM
1989GMCJimmy's Avatar
Default L76 Cam for Jimmy
I am going to be a full restomod on a full size 89 Jimmy. I own a shop and we had to install a used engine on a Vortec Max truck, and when I found out the engine was an all aluminum L76 core I didn't send it back. Bought the GMC and viola, a home for the L76.
Truck has 35's 4.56 gears and will have a 4L60E. Seems I won't be making the most of those rectangle port heads in this truck application, but whatever. I was told by Justin at Blackbear who is a friend of mine that he likes the Comp 54-412-11 XR265HR Specs are as follows
RPM range 1200-6000
Intake at .050 212
Exhaust at .050 218
Intake lift 0.522
Exhaust lift 0.529
LSA 114.
I want good sturdy midrange as this is a truck, and it will be used to tow from time to time. Thanks for the assist.
Old Oct 27, 2021 | 05:21 PM
That will be a great cam for your truck! With -13 overlap it will run smooth and still have great low end and midrange.
Old Oct 27, 2021 | 05:55 PM
What kind of horsepower and torque would I see with long tubes and a tune with this?
Old Nov 1, 2021 | 01:14 PM
I have a BTR Stage 2 NSR cam that I was going to use for this engine when it came in the shop. Since it sounds like this Comp unit is worth buying do I need to move off of the LS6 valve springs I had the machine shop install that were originally for the BTR cam and use comp 918's instead?
Old Nov 1, 2021 | 01:48 PM
The LS6 springs will be fine, with enough lift capacity.
