5.3 camshaft question
Old Dec 10, 2021 | 02:06 PM
Tcombs67's Avatar
Default 5.3 camshaft question
I have a 2012 5.3 engine. The engine has 58x reluctance wheel and a 1x camshaft reluctance wheel. At WOT I have a dead spot (cut out) but eventually recovers. I have holley terminator x efi system installed. When engine under load at WOT cuts out (dead spot) I get crank sensor alarm on terminator x. Called holley, they helped me disable the cam sensor. After this was done problem went away. My question, is this a problem having a 1x cam reluctance wheel with 58x crank? Holley said cam sensor could be bad.
Old Dec 10, 2021 | 02:28 PM
Normally a 58x reluctor crank works with a 4x cam sprocket, BUT the Term X might be working around that. All the cam sensor is for is to tell the ECM which stroke the crank is on (TDC compression/power or TDC exhaust/intake). Holley might rely upon it for other purposes. Try a new cam sensor and see if it solves the issue.
Old Dec 10, 2021 | 04:29 PM
Tcombs67's Avatar
Replaced CAM sensor and no cut out at WOT so far.
thanks for the reply and help.
