AHP 434 LS Build Incoming !
Is your exhaust port small enough?
So I recently had the opportunity to build some headers for a Ford Coyote FSS/_ car. I built a 421 header mainly because It is a 310" (I think) motor and uses a 3 speed automatic transmission. So from my point of view it needs all the help it can get at the bottom of the power band. Most people would be suprised to know the average rpm of a run with a automatic transmission. (Your RacPac can tell you that)
As many of you many know I will always determine the area of the exhaust port I am presented with from the Engine builder/head porter. I was surprised to find that the exhaust port at the flange was not ported (or at least did not appear to have been. Since it was a SS engine I would be sure that a lot of work probably was done inside but that does not affect me,) and measured 1.480" round. This was as the factory made it. I am sure several folks here on Speed Talk will calculate the valve area/Curtain area data and everything but to say the least I was shocked at how small and round it was. I was impressed
I had run into Coyote motors back in 08ish? I think at multi-matic and Elan Motorsports and the port were not round, they were WIDE and rather large. (not unusual). So I have to say Ford has done some work and made the exhaust ports SMALLER! a lot smaller! and this is something to note. OK?
So for anyone who has taken my tube size/horsepower range chart to heart, ah... a 1.625" tube off the head can handle 750 hp.
Calvin ElstonElston ExhaustMatthews, NC 28104346-704-4430Blog: www.exhausting101
At least that is what I've found on the LS subject. Another friend of mine did the same thing on his 434 SBC that had 2" Schoenfeld's, he found a set of stepped 1 3/4 to 1 7/8ths Hooker Super Comps for his 3rd gen. He, on the other hand, picked up 5 tenths on his motor pass. That's huge for just a header change. His motor loved those headers on spray too. We were all shocked at the outcome on our motor. Apparently these LS motors like to get the air out just as much as in. Which makes no sense with the size of the exhaust ports on the heads.
We ended up playing with tuner pipes different diameters and lengths too. Found a bad *** expander you use a impact on to expand the pipe. Works unbelievably good. Did 3" stainless to 3.5" no sweat. Sweet spot for us was 3.5" straight off the collector with a 3.5" mandrel bent turn out, to get the air out from under the car, at 24" total length.
who I tried my best to imitate (just smaller). John B. Go take a look and the reason for my investigation. That quote was from a 19+ page thread and it F"ed me up on size of the 1 step. What I seen John do made sense and a bit of research made it even more logical. Yrs later became a member of Speedtalk, read what a top End exhaust header specialist had to say and his thoughts on the subject of a Header.
Reference back to John...
For most, you bolt on the headers that are made for your car and hope for the best.
I am like a 20 YEAR member, I lost my PW a few years back but have my same exact car.
My previous handle was “Mirek” hence my new handle “Mirek Again”
Mods if you see this help a brotha out
