Morel 7717 lifters
Old Jan 13, 2022 | 07:59 AM
Michael Gerace's Avatar
Default Morel 7717 lifters
Has anyone ever use these lifters or any other brand and had one that wouldn't go in any of the holes. If so what did you end up doing? All the others fit in all the holes.
Old Jan 13, 2022 | 10:18 AM
grinder11's Avatar
If your original LS7 lifters all fit in their bores, and one will go in the bore in question, you have a lifter with an oversize lifter body that somehow made it thru quality control. I'd call Morel, and explain the problem to them.
Old Jan 13, 2022 | 11:22 AM
bbond105's Avatar
Try swapping the lifter that want go, into different hole to try to determine it the problem is with the lifter, or the lifter bore.
Old Jan 14, 2022 | 09:11 AM
It's the lifter. Already on it's way to be swapped out! Let's hope that one is good!
Old Jan 14, 2022 | 09:44 AM
grinder11's Avatar
Nice catch! Oversize lifter is what I was thinking. Glad it was oversize to the point of not going in. If it would've been able to be installed, but maybe enough oversize to cause damage, that could've been disastrous!! The lifter bore would expand faster than the steel lifter body would, but on cold startup, who know what couldve happened?
