Ls7 crank swap
Old Feb 6, 2022 | 01:46 PM
Atomic Vette's Avatar
Default Ls7 crank swap
Hay Guys! I have an ls7 with a bad crank! I want to swap out the old crank for a good stock LS7 crank! Given that the Bob weight should be the same! Do I need to rebalance the new used LS7 crank!
Old Feb 6, 2022 | 08:36 PM
No you don’t need to balance this. It will be as it was from GM. It wouldn’t hurt to have a good shop check the balance if your looking to “improve” over what GM did with this, but honestly the LS7’s are pretty decent for an OEM offering in that department.
Old Feb 7, 2022 | 10:40 AM
grinder11's Avatar
As long as you re-use the Ti rods, you should be fine with OEM balance. BUT, what exactly happened to the crank? I'm wondering....the old 'chicken and the egg' syndrome comes to mind! Did your rods CrN coating go bad, and take out the crank? Or???
