LS3 Headgasket Q
Old Mar 22, 2022 | 10:36 AM
shakenfake's Avatar
Default LS3 Headgasket Q
Boring an LS3 out to 4.07 am I able to use a stock LS3 head gasket? Using L92 heads, no milling. Pistons I am looking at are JE 311981. I do not believe I will have PTV issues with this setup.
Just wondering if I can use the stock LS3 gaskets in terms of bore size?
EDIT: I believe that the LS3 gaskets have a bore of 4.085? Can anyone confirm that as well?
Old Mar 22, 2022 | 10:06 PM
The LS9 headgasket is 4.100 bore. GM part #12622033. Summit has them in stock.
Old Mar 23, 2022 | 08:10 AM
shakenfake's Avatar
Thanks @Che70velle
Another question I have is, what is the tolerance for the gasket being larger than the cylinder bore? I figure you don't want it a whole hell of a lot bigger but just curious if there was some guideline to follow.
I think you are right though the LS9 head gasket should work.
Old Mar 23, 2022 | 10:04 PM
Originally Posted by shakenfake
Thanks @Che70velle
I match headgaskets to chamber size first, then bore size, if there’s room. If the gasket fits nice and tight around the cylinder, but hangs over into the chamber, it will cause two problems. First, it will cost you power by interrupting airflow and flame propagation. Second, it will cause hot spots…particularly with the MLS gaskets…that can cause detonation
All headgaskets are going to naturally sit a tad big on the bore size, while properly fitting the chamber, unless it’s a custom build and the cylinder head guy hand blends the chamber to accommodate a particular headgasket that’s usually going to be a custom Cometic or the like. So your basically going to have a tiny space around the top of the cylinder to deal with, and there is a formula to figure the area (along with crevice area above the rings if your really picky) for compression numbers.
Old Mar 25, 2022 | 02:32 PM
RonSSNova's Avatar
Crevice area. I’ve thought about that. I’ve never seen a CR calculator that includes it.
Rough idea on how many CC it is for the stuff we work on?
Old Mar 25, 2022 | 08:47 PM
You’ll never guess where I (we) got the formula…called Smokey Yunick himself. Smokey was always cordial as long as the call was interesting to him.
Formula is rD*π/4*(bD^2-pD^2)
rD=ring depth…top of piston to top of ring
bD=bore diameter
pD=piston diameter above the top ring
Here’s a link to a easy online plug-n-play crevice volume finder.
https://www.vcalc.com/wiki/KurtHeckman/crevice+volume
edit…we should build a page for hard to find formulas and make a sticky…I’ll work on this.
Old Mar 25, 2022 | 11:00 PM
Also, a say to figure the volume between head and block, between inside of head gasket and bore edge.
