821 Heads with LSA Features
LSA "wing" bump in the intake port, short inside radius side wall of the port as it turns
LSA supercharger locating dowel receiving bore on intake sealing surface face
Seemingly hollow intake valves (mass 80-83g, forgot exact)
Additional little casting nugget bump in combustion chamber between intake valve and combustion chamber edge (this common on any?)
Infamous "blue" valve springs
1 of each of the steam ports on each head factory plugged off, I think most later heads have this regardless....
Were 821's used on LSA's? Were intake port wings used on non-LSA engines? Locating dowel hole? Any of this making sense to anybody? Most indicators I researched just produced a conflicted result.
Thanks as always.
As far as the little bump between valve and chamber edge, a picture would be helpful there.
The rest concerns hardware that anyone could attach.
