L92 Block Swap
Old May 9, 2022 | 09:18 AM
Redduck's Avatar
Default L92 Block Swap
Hi All.
I have a new L92 that I got very cheap since it was dropped on delivery and the starter mount broke off the block. So now, I need to essentially swap everything from the broken block to a new one and I have a few questions.
First, is this a bad idea? I was thinking of just buying a new GM block and making the swap? Since I am moving the crank and rods, I would assume I don't need to worry about those matching up. Should I be worried about moving the crank to the new block and just using the new bearings that are already in the old block? What about using the same rod bolts? Since the older motor has never even been started, I would assume rod bolts would be ok to reuse. What about head bolts?
Also, while I am there and since it will be apart, I am thinking it is better just to swap the cam out to a better one and get rid of the VVT. But, what about using the same lifters on the new cam? Again, this engine has never run, so everything is brand new.
I appreciate any input and advice.
Ken
Old May 9, 2022 | 09:37 AM
IF- starting with anew block, and-
IF- the L92 was never started and run-
THEN- everything should swap over painlessly and to no ill effect
Old May 9, 2022 | 09:54 AM
Redduck's Avatar
Thanks! Also no problem with reusing the head and rod bolts?
Old May 9, 2022 | 10:48 AM
theunderlord's Avatar
Head bolts are one time use only. Rod bolts are ok to reuse.
Old May 9, 2022 | 12:28 PM
^^^^THIS^^^^
If desired, get ARP head bolts which are reusable. Not totally necessary though...
