Not the same ol' knock
The cliff notes are that I'm 98.5547% sure this is rod knock. I'm an experienced tech, but my first LS.
Its a GM Performance connect-and-cruise kit 6.2L LS3/4L65E, bought about 2018 while the Van was being built and currently has 800 MILES on it. 800. I was driving normally, it started to knock intermittently going like 25mph, and by the time I could get a block to a Carls Jr parking lot it sounded like this.
I can't imagine what you could screw up on install to hurt an LS that bad. It has been babied like you'd baby a nineteen thousand dollar, completely GM stock, brand new powertrain. You could say I'm a little more than angry
GM Performance says suck it, its over 12 months old, so we aren't doing anything
. So, assuming rod knock, what the heck could have caused it? and what the heck do I need to fix it? Rod bearings? Rod and crank bearings, Rod bearings and rods? It had been sitting for about an hour at a buddies house, on a warm day, and this started 2 blocks after leaving. So, not over heated.
It still has 40psi oil pressure at cold idle, sender is at the lower port by the filter.
Compression is 125psi on #1 and #7 and the rest at 150psi.
Removing the coil plugs at idle one at a time = no change.
Oil was drained through a cloth and put back in, not a single piece of glitter but a tiny/tiny bit of grey sludgy stuff in the pan? I haven't pulled the oil filter and I did initially shut it off really quickly.
Plugs look OK
Valve covers off and all the rockers move while cranking. I didn't spin the pushrods.
So all I can do is pull this damn thing out and yank off the pan?
I have a 6.0l iron block engine for another project. Easy to swap physically but what about the GM ECM I'm using now?
And a pic, because pics rule.
But thank you guys for the replies so far. I know what I'm in for, I would just like to be as prepared as possible before I dive in. I'm pretty scared of killing the interior:
Have you taken the AC belt off and serpentine belt off to verify its not something up there?
Thats a really high pitched sounding to be rod knock but anything is possibly I guess.
Defiantly pull filter
it just doesnt have the "Normal" rod knock sounds that im used to.
Ever had a hard time cranking it? Ive had one hydro lock with fuel and tweak a couple rods just enough to bend them ever so slightly and it sounded similar to that.
I don't know if it made it's way out the exhaust.
I don't know if it was big enough to bend the rod, kill the bearing and thats what i'm hearing.
I don't know what "it" is. Foreign object from before or because of the custom cold air intake ('74 Van)? Chipped valve seat?
At least I know what I'm in for. Ugh. I'm going on vacation.
All other cylinders look ok in your engine?
