Same intake and exhaust duration, same DCR, same lift, different LSA
Old Oct 9, 2022 | 03:04 PM
old motorhead's Avatar
Talking
Just a thought, but with those cam specs, you are a stone's throw away from Spinmonster cam specs(230/234 114) Just from my experience, most 22x cams either do not make any more power than a smaller 215-219 cam and/or have less driveability like what you are trying to avoid. For most of what I build, either customer wants stock driveability or wants big power, not much in between. Spin has been on here lately, you should DM him. His cam works, it's proven and has tons of reference points. The 224-227 have a lot of reference points too, but very few have stood out and outshined something else slighty smaller/bigger. Just some thoughts on what I have seen. For reference, I am taking my own advice and going from a 215 cam to a 230-238 cam. Not even looking at the 22x somethings at all.
I've been running cam 4 (226/234 115+4 .620/.620) mentioned in my first post for the better part of 4 years now. The SBE LS3 has 821 heads that were ported and milled (.010) by Tx Speed, .040 head gaskets, ported and rod modded LS3 intake manifold (GPI), underdriven crank pulley, 1.875" long tubes, and full 3" exhaust. It made 500/454 at the wheels on a dynojet. Probably have about 40K miles on the mods now (did all the work at about 30K miles and it has 70K on it now). About all I've done to it was change the valve springs and rocker arms a few thousand miles ago. BTR Platinum springs and stock rocker arms. The cam is custom specced by me with Cam Motion grinding it.
I did a search and Holdener did an LSA comparison with a 108, 112, and 120 LSA cams with the same lift and duration. He never mentions whether any of the cams had any ground in advance. Of course, with no advance ground in, the 120LSA cam was dead down low and made an insignificant increase at the very top end.
I think I understand that intake duration and lift determine power potential with the intake valve closing event determining where in the rpm band the power will be made. I have absolutely no idea how ground in advance effects the exhaust side. Anyone care to try and explain this to a farm boy. Try not to use too many big words.
I did consider Spin's cam but wanted to see what could be done with even less overlap. Plus, I absolutely hate any kind of bad manners. I'd rather have a few less hp than having a bucking and lurching car telling me which gear I need to be in.
And all good stuff above. Very enjoyable and enlightening read.
Old Oct 9, 2022 | 07:53 PM
Originally Posted by spanks13
Is that a restrictor plate cam or unrestricted?
unrestricted. .850 lift at a 1.8 rocker on both sides. I’ve already said more than I wanted to. Don’t tell anyone…😜
Old Oct 10, 2022 | 07:36 AM
99 Black Bird T/A's Avatar
What would you rate the typical hp of a 215 to 219 cam builds vs the 220 to 230 cam builds?
Back in ~2002 a local shop had a little 216/220 ~.53x/.52x cam that would make 400 to 405 whp in a M6, 5.7 Stage 2 ported heads, cam, LS6 intake 1 3/4 LT header car. The shop owner said was it was his favorite cam.
However, stock exhaust system typically killed ~40 whp off of the package. Most customers interested in that H&C seemed to want to keep stock exhaust including cats.
Old Oct 10, 2022 | 08:26 AM
grubinski's Avatar
I had a GMPP Hotcam in my LS376/480 crate motor. These are 218/226 IIRC, and typically make about 420 whp. The GMPP ASA that I replaced it with, 226/236 made 462 whp on a Mustang dyno.
Old Oct 10, 2022 | 09:11 AM
462whp is pretty spicy for the GMPP ASA cam A++. How's driveablity etc?
Old Oct 10, 2022 | 02:21 PM
Spinmonster's Avatar
LSA shifts the power band up or down. A 114 shifts the power band down compared to a 115, 100rpm giving up top end in exchange for low end.
Advancing does the same, retarding moves it up.
Added exhaust duration adds to top end due to scavenging but hurts low end due to overlap.
Raising static compression adds to the entire power band and improves driveability making a cam act as it does in a bigger displacement without a penalty in power band shifting by about 3% in power gains. On 500hp you would be at about 515hp with a full point in compression. Low end Tq improves a bit more by about 4%.
Cam designers that narrow the LSA and add advance are doing it to improve dynamic compression without removing heads. If you bump static compression, there is no need to advance a cam on a narrow LSA.
On an LS3, a 227-230 intake duration on a 114+1 peaks at about 6300rpm where the intake manifold is forcing the peak due to runner length. If you use a FAST intake there are modular runner swaps that allow you to change this. A 230 on a 115+3 is also about 6300rpm. A 230 on a 112 with 3 degrees advance would need more exhaust duration to extend the power band back up to 6300. Cams that peak the power band coincident with the intake manifold result in the best peak HP reading on a dyno. Cams that don't peak coincident with the intake manifold have a lower number that appears as a flat line in the high rpm on a dyno.
Once durations are chosen, the LSA and advance are picked for you in a given power band goal.
https://www.compcams.com/cam-timing-...paration-angle
Old Oct 12, 2022 | 04:52 PM
SteveJewels's Avatar
Veteran: Navy
Thank you @Spinmonster
I am approching the time to pick a cam so I have been reading up on cams. This is very helpful.
Old Oct 16, 2022 | 05:50 PM
grubinski's Avatar
Sorry, just saw this. I’m old, and did not like the street manners of the ASA cam, or the fact that it only got ~23 mpg highway in a very light, small car (Miata).
I went to better heads, more compression, and a much milder cam (1.5 degrees overlap instead of 11), and the car made 10 more whp, but more importantly, drives **so** much smoother and gets 31 mpg highway.
Tony Mamo did the heads and spec’d the cam … he knows his ****. 👍
Old Oct 16, 2022 | 06:28 PM
^^^^ that's a win, win, win some more outcome!
Old Oct 16, 2022 | 06:39 PM
grinder11's Avatar
Originally Posted by Kawboom
Less lobe separation angle = more torque and low end, overall lifts the torque peak.
More lobe separation angle = less torque, possibly equal high rpm power, less chop at idle.
Of these I would pick the 113.
Just curious as to why the 113° over the 112°? Though it won't make a lot of difference either way...
Old Oct 16, 2022 | 06:54 PM
grinder11's Avatar
IIRC, the hot cam was/is 219°/228° duration, but I'm not 100% on that one.....
Old Oct 16, 2022 | 11:18 PM
  #32
KW Baraka's Avatar
You are correct.
LS376/480 495HP Hot Cammed LS3: GM Performance Motor
KW
Old Oct 18, 2022 | 02:23 PM
  #33
Fast355's Avatar
To this day I do not understand why people want to calculate overlap at 0.050 and say they have zero or negative overlap. Overlap is more accurately calculated at 0.004 or 0.006. My 271/284 @ 0.006 on a 108 LSA and 106 ICL or commonly expressed 108 +2 camshaft in my 11:1 383 has perfect manners. It has 61.5 degrees of overlap. Using the 0.050" method, with its 218/228 @ 0.050 it has 7 degrees of overlap. I still have cats but it is nowhere near burn your nose or eyes rich at idle even before the cats light off. You can make a cam with substantial overlap still idle cleanly if you have the start of injection timing right in the tuning. By waiting until the exhaust valve is nearly closed to start injecting fuel, raw fuel cannot make it into the exhaust during the overlap period. I have seen some bucking with some cams at low rpm. That being said I typically see that most on cams that have an early IVC and are operating at higher load at lower rpm. With a 0.006 IVC of 61.5 my 383 will pull a light load smoothly down to 1,200 rpm and take full load smoothly by ~1,600. It pulls 7,400 lbs up a 6-8% grade in overdrive at 75 mph and 2,250 rpm smooth as silk operating at a stoichiometric air/fuel ratio.
Old Oct 18, 2022 | 03:15 PM
  #34
Fast355's Avatar
I forgot to mention earlier that another highly overlooked area when it comes to overlap and what works in an engine is the valve seat angle. A 30° valve seat will flow more air immediately when the valve lifts off the seat then a 45-50° seat will. A steeper valve seat angle will tolerate more overlap than a shallower angle will because it decreases the flow during the overlap period.
Old Oct 18, 2022 | 06:04 PM
  #35
grubinski's Avatar
That is very interesting. What would you say the magnitude of this effect is? What is the ‘X’ in “45 degrees will tolerate X degrees more overlap”? Does the steeper valve angle also cost flow near IVC, thereby necessitating a later IVC to achieve the same upper rpm power?
Would you consider this a fundamental item, or maybe just a second or third order effect?
Old Oct 18, 2022 | 06:43 PM
  #36
Fast355's Avatar
I do not know that there is a X degree kind of rule. The head flow is influenced by the seat angle in different lift areas though, so it will affect how the cam works. That is why the good custom cam grinders want the cylinder head flow specs at various lifts. In the article below a 30*, 45* and 50* angle were cut on the same cylinder head, run on the same engine, with the same camshaft. The only difference was the valve seat angles. I was surprised at how much only the valve seat angles changed the flow numbers and torque curves. What that clearly shows is that the head flow numbers can be influenced by valve seat angles with the same exact cylinder head ports and that the camshaft needs to be ground to take advantage of the whole flow curve at whatever seat angle is going to be used. On the test cylinder head at 0.150 lift the intake port had 15 cfm flow difference between a 30* seat and a 15* seat. On that setup the 30* seat angle will absolutely make a camshaft with the same overlap operate more radically then the 50* seat angle cylinder head. I wish they had taken a measurement of intake vacuum for each combination.
Rethinking The Valve Job (motortrend.com)
