LS3 in Truck Camshaft Selection
6.2 Stage 1 LS Truck Camshaft (206/216-117+4) - Cam Motion
KW
This is a baby cam that is ground for lower RPM torque (essential to get heavier vehicle moving) and can EASILY be driven as a daily driver in any traffic/weather conditions.
In the greater scheme of things, this is a 'baby cam'.
KW
Running that setup through Engine Analyzer as a stock LS3 with truck intake runner dimensions, with that cam and 1 3/4" primary long tube that has ~30" long primary tubes and 3" collectors with free-flowing mufflers predicts about 480 hp @ 5,500 and more importantly over 450 ft/lbs from 2,500-5,500 rpm with 507 ft/lbs @ 4,000 rpm. At 2,000 rpm it is already at a healthy 425 ft/lbs. At 6,000 it is still holding on at 470 hp. Predicted idle vacuum about 16 in/hg which should work well with vacuum boosted breaks if the truck is not hydroboost equipped.
I ran 6 different Rectangle port spec'd cams and 4 different Cathederal port spec'd cams in the same model. Using similar intake duration and advertised powerband numbers from the 3 different manufacturers the high lift, wider duration split cams lost torque under 2,500 each and every time both WOT and at 250 cfm simulating part-throttle with only moderate gains starting at 5,500+, Assuming this truck has 3.73 or 4.10 gears and a near stock size 30-31" tall tire it is going to reach 5,500-6,000 rpm one time and one time only at WOT 1-2 shift while towing at legal speed limits. The 1,500-5,000 rpm torque curve is much more important than the peak power at 5,500-6,000 rpm.
Just some info on how I arrived at the XR269HR being the cam I would choose if it were my tow vehicle.
The XR269HR shows about 5-8 numbers higher under 3,000 rpm with the highest being 8 ft/lbs @ 1,500 and drops from 1,500. From 3,000-4,000 the Summit cam edges out the XR269HR by 3-5 numbers in torque. The summit cam showing 512 ft/lbs @ 4,000 compared to the 507 @ 4,000 from the XR269HR. The largest difference is at 5,000-6,000. The Summit cam climbs ahead of the XR269HR by 4 hp @ 5,000, 10 @ 5,500 and 16 hp @ 6,000. At 250 cfm of airflow illustrating part throttle, the XR269 is up 2-3 until 3,000 and the Summit cam is 2-4 higher from 3,000-4,500. Not that you would really rev to 4,500+ with ~1/4 throttle, but it is possible, both are in the 300-315 hp range @ 4,000-4,500.
I feel this test just re-iterates the torque curve being extended at high rpm by longer exhaust duration while giving up some low-speed torque due to an earlier EVO. The LS3 heads flow so well even with their "weak" exhaust port that the added lift of the 0.600 camshaft just does not have much benefit at this rpm and horsepower level. With 297 cfm of port flow at 0.500" the 821 castings are not being taxed by a sub 500 hp engine that is only spinning 6,000 rpm. Even if you ran the engine out well past the peak power of a mild cam under a truck intake, the Summit cams longer exhaust duration and 0.600 lift only add about ~22 hp @ 6,500 rpm.
My 4L85E with 3.73s and 30.5" tall tires spends most of its life when I am towing heavy in the 2,500-3,000 rpm range in 3rd gear at highway speeds. If I am foot to the floor I am at ~4,000 rpm at 70 mph. If the roads are winding, narrow and I am at 50ish MPH foot to the floor in 2nd gear is just over 3,000 rpm. I do not see much need looking at power at 6,000-6,500 rpm with a 4spd Auto and towing unless you just want to destroy things. Sure, you could spin 6,000+ in 1st gear at 50 mph, but why would you want to if you have the grunt to pull 2nd or 3rd gear at the same speed? 2nd gear at 3,000 doubles fuel economy compared to 1st gear at 6,000 rpm. Just for the record, I am not saying either of these cam choices lack power at 3,000 rpm. That being said, I have seen some guys put some crazy long duration, wide split cams in their build. They then wonder why it will not make it up a decent hill without having to run the thing in the lowest gear they can at that speed to rev the engine 5,500-6,000 rpm.
That cam should work pretty well in a stock LQ4. Then again, a set of 862 or 706 heads and a cam with a later IVC would be just as torquey if not more and make more power across the whole rpm range while having a smoother idle. Either way will work but the 317 heads are pretty lazy in port velocity at lower rpm compared to a cleaned-up set of 5.3L heads. My LLoyd ported 862s flow nearly 300 cfm and still have intake ports that CC about the same size as the stock 317s. When you have 210-215cc of port area flowing ~250 cfm vs 215cc flowing 300 cfm, the slightly larger ported 5.3L ports are flowing air at a much higher velocity, aiding in cylinder filling at lower rpm. By virtue of a higher static compression ratio via smaller chambers as well as ramming more air/fuel into the cylinder the ported 5.3L heads do not need as early of an IVC to trap the same cylinder pressure as the 317s. This allows for as much torque, but a broader curve overall. The small 4.8/5.3L chambers are also very octane tolerant and do not require as much timing as the larger open chamber 317s. I have seen the 317 heads on a LQ4 want as much as 28-30* of timing to make peak power. The small, closed chamber 5.3L heads make their peak power at 24-26* of timing. It is a subtle difference but a substantial one in making torque on cheap pump gas.
