Issue with crank position sensor/ relearn/HELP!!!
Old Feb 12, 2023 | 12:58 AM
R_shum's Avatar
Default Issue with crank position sensor/ relearn/HELP!!!
I have a 6.0 LQ4 engine that I converted to 58x for a swap project. Relocated the cam sensor, drilled and tapped new knock sensors, swapped reluctor rings, etc. The car runs and drives like it’s should but I have a check engine light for a crank relearn. No matter what I do I can’t get a relearn to work. I’ve used multiple scanners, tried a new sensor and even checked the wiring. When I hook up the scanner it reads Rpm, but when I go to rev it up I get an error code with something along the lines of “conditions not meant”. I follow the steps verbatim so it’s got to be something else. Wondering if anyone can give me some input here!!
Old Feb 12, 2023 | 09:35 AM
LS1Formulation's Avatar
What engine management? When you swapped the cam gear to the timing cover, did you also add the 4 pole cam sprocket? How was the reluctor wheel installed? With the correct tool?
Old Feb 12, 2023 | 03:42 PM
R_shum's Avatar
I am using a stock e38 ECM and all my tuning is through HP TUNERS. My cam gear was swapped out to the correct gear aswelll. To swap the rings I baked the crankshaft in an oven, took the 24x off , then heated up the 58x with the oven and slid it on. I Drew a line centered on a hole that both rings had and went off that for alignment. Here is a picture with the 24x, but I do not have a picture of the 58x after I swapped it on.
Old Feb 12, 2023 | 06:56 PM
There's no chance you installed the reluctor wheel backwards?
Old Feb 13, 2023 | 02:49 AM
R_shum's Avatar
I checked it out and it’s definitely on the right way. I looked at some pictures of new 58x cranks and the ring seems to be oriented just right.
