Power Estimates?
Old Feb 18, 2023 | 07:45 PM
B4CMaro's Avatar
Default Power Estimates?
Putting together a new combination. What do you think it will make? Suggestions appreciated. Parts listed are parts that I have. Want to get a 3200lb race weight car to the 5.50's - 6.0s no prep and still drivable.
403 Ci ls2
Forged internals.
k464x05 pistons -3CC
.040 gasket
12.2 compression
~.04 quench
Port matched ls3 Fast 102 with mid length runners
TEA trickflow 255s milled to 63CC
Johnson reduced travel lifters
BTR v2 rockers.
btr assembled and shimmed .660 plats
242/256 110+4 .646 cam
manual rack and brakes.
factory WP
1.875 headers and dual 3" exhaust
NX Plate kit. spraying 150 to 300 progressed (may go direct depending on how it works out)
Maybe close to 670fwhp na?
Old Feb 18, 2023 | 08:11 PM
84ta406's Avatar
Similar to my 403 but I used MMS 235 heads, 11.8:1 CR and cam was 243/249 .675/.675 114+3. Made 667fwhp at 6650rpm.
Old Feb 18, 2023 | 08:24 PM
B4CMaro's Avatar
that's not bad, mamo heads seem to make great numbers. i was hoping to run mine out a bit more hence the ls3 top end. Hopefully it will run out to 7500ish.
Old Feb 18, 2023 | 09:58 PM
DualQuadDave's Avatar
403 Ci ls2
Forged internals.
.040 gasket
12.2 compression
~.04 quench
BTR v2 rockers.
factory WP
Do you already have the TFS heads?
Old Feb 18, 2023 | 10:01 PM
B4CMaro's Avatar
yes i do, how come?
Old Feb 18, 2023 | 10:07 PM
yes i do, how come?
Just asking because I would recommend a different LS3 head. It's ok though, they are not bad at all. I would definitely do a 2in header though. What valves are in the heads? Hollow or solid? Considering you want to turn it up, hollow or Ti is the way to go.
Old Feb 18, 2023 | 10:11 PM
B4CMaro's Avatar
lots of people i talked to were biased eiher towards afr or tfs heads, the heads are from tooley and were shipped by TEA so i may have to ask them if they incorporate their hollow valves. I was looking into 2" headers, may go that route once it comes apart. and ceramic coated
Old Feb 18, 2023 | 10:21 PM
Def ask on the valves, there is a lot of power in that. I don't like AFR's, I was going to suggest PRC 260's(I have a set going on my LS2), or Mast 11 degree. Both are real nice for the $$.
 Michael S. Palmer
Old Feb 18, 2023 | 11:33 PM
B4CMaro's Avatar
I'll definetely call them Monday and ask them. I assume they should be since all tea tfs 255s come with hollow valves according to the website but it would be a good thing to check.
I had the masts and prc on my radar but opted for the tfs because of availability, price and for the port size had really strong numbers. Assuming the data is legit. They should hopefully perform well with the aggressive street cam and shorter 6" fast runners.
Old Feb 19, 2023 | 01:12 AM
jayyyw's Avatar
Make sure you put good springs in it if you want to rev it out that far. Like a PAC 1208x kit, shimmed to what you need.
Old Feb 19, 2023 | 02:01 AM
KW Baraka's Avatar
I have PRCs on one car and AFR on another.
But based on what they did on my 427ci LS3, I would rate the AFRs as the better product.....but I do like my PRCs! ;-)
KW
Old Feb 19, 2023 | 08:01 AM
B4CMaro's Avatar
They installed and shimmed their .660 spring kit on their own recommendation.
Old Feb 22, 2023 | 07:56 PM
jayyyw's Avatar
Just some personal expirience: The .660 BTR spings in my LS7 heads only lasted about 6months being rev'd out to 7500rpms almost daily. They started to float after that. I was running stainless valves which are probably heavier than what you are going to run. Just something to be aware of and keep an eye on.
Old Feb 23, 2023 | 08:20 AM
B4CMaro's Avatar
what cam was in it?
Old Feb 23, 2023 | 09:20 AM
grinder11's Avatar
FWIW, Tooley was at, and developed a lot of, the TEA ported heads before he left to start BTR. He is very good. As for power, I'm guessing closer to 650fwhp. YMMV.
Old Feb 23, 2023 | 09:24 AM
grinder11's Avatar
KW
It is hard to go wrong with AFR heads. I mean, look who designed them..
Old Feb 23, 2023 | 10:06 AM
spanks13's Avatar
You have a much larger cam than needed for your ET goals and the amount of spray you plan on using
Old Feb 23, 2023 | 11:00 AM
B4CMaro's Avatar
Guys at tooley said they are solid intake valves. But they are confident valve float will be controlled with the .660 springs
Old Feb 23, 2023 | 11:43 AM
B4CMaro's Avatar
I was hoping to spin it to around 7200 - 7500.
Old Feb 23, 2023 | 08:56 PM
jayyyw's Avatar
what cam was in it?
RPM B3 - 243/258 .660/.660 114+3 Not too aggressive.
