Newer LT valve springs in LS heads
Old Feb 22, 2023 | 07:57 AM
86LSC10_SC's Avatar
Default Newer LT valve springs in LS heads
Hey all...pretty new to LS engines and read somewhere that I can use newer LT valve springs on my LS heads. I got a set and notice that they are about 3/8 or so taller than the beehives from a pair of 05 706 heads. Is this something that will cause issue or should I just get fresh ls6 beehives? Will be running the Chopacabra cam in a gen iv 5.3 with afm delete that will be going in my 86 gmc 1500
Old Feb 22, 2023 | 08:39 AM
TurboBuick6's Avatar
No you cannot use the LT spring in an LS spring. They have different solid heights and you will bind an LT spring in an LS application.
