Gaskets
Old Feb 26, 2023 | 07:35 PM
Mattyc's Avatar
Default Gaskets
What gasket kits are recommended for a ly6? Fel pro or mahle or are they both pretty much the same!
nothing crazy as regards to mods just a btr truck norris cam, btr springs, ls7 lifters new trays and a trunnion kit. Obviously I've taken all the old gaskets off and going to put new ones back on and thought i might as well change as much as i can while the engine is stripped on a stand!
thanks
Old Feb 26, 2023 | 08:02 PM
LS1 TJ's Avatar
I typically just go with NAPA gaskets. For header gaskets I use Fel Pro. I haven't had the heads off my LS swaps but I would say Fel Pro OEM replacement head gaskets?
Old Feb 26, 2023 | 09:11 PM
I try to use GM gaskets and seals when I can. I like Cometic headgaskets. Of course it costs more, but there’s a reason for that.
