383 Stroker build
Old Mar 27, 2023 | 05:29 AM
Ltkilowatt's Avatar
Question 383 Stroker build
Good Evening
Question, to make things short my current set up on my 01 SS is everything you can do to the top end without blowing up my stock bottom end. I will be going to an iron block 383 Stroker over the summer, but my question is would it be better to buy a stock iron block and going from there, or already buy a pre-built iron block (link below) and swapping everything over on the top end? Also, if i bought a pre-built would it be "Safe" or would i have to worry about "OILING"? (
Any info would help me and thank you.
ATK High Performance Engines SP78 ATK High Performance Chevy LM7 383 Short Blocks | Summit Racing
Old Mar 28, 2023 | 11:25 AM
02EBC5Z06's Avatar
Why do you want to put an iron block in the car.. Is this going to be an all motor car, turbo, blower? What is the car used for.
Old Mar 28, 2023 | 11:43 AM
LFSADRG's Avatar
I went with a TSP aluminum 383 short block. The car is almost ready to be road worthy. Suspension and exhaust situation.
Old Mar 28, 2023 | 12:15 PM
Ltkilowatt's Avatar
yes, the grand scheme of things I am going to put a pro charger in it eventually
