12571048 casting overbore
Old Mar 29, 2023 | 10:49 AM
Lewy-d's Avatar
Default 12571048 casting overbore
I've searched and most threads are about sleeving. How much can this block be overbored?
thanks
Old Mar 29, 2023 | 05:42 PM
thanks
Being an aluminum 5.3 block, I wouldn't go more than .030, but that's a guess. I looked for an actual limit, but came up empty.
What are you doing?
Old Mar 29, 2023 | 08:08 PM
DualQuadDave's Avatar
.100 over, maybe an additonal .005 for a clean up after that, but it's questionable. .100 over has been a ton of times.
Old Mar 30, 2023 | 06:37 AM
Lewy-d's Avatar
Thanks for the replies. I'm building it mostly NA with a little nitrous (like a plate behind the throttle body). It seems there's more 3.790" pistons available than 3.785". I'd like to keep it small for future rebuilds. But that could be old school thinking.
Old Mar 30, 2023 | 02:07 PM
LS1Formulation's Avatar
I have an LH6 aluminum block at the machine shop presently, and I'm going .030 over. They have more than enough meat to go all the way out to 3.905. That leaves me a lot of material for future rebuilds, but I'm boosting this thing and probably will sleeve it before I bore it. Don't be afraid to go bigger - .020 over is pretty common.
