To lap or not to lap?
On the other hand, everyone seems to lap valves, even if everything is good and you are just reinstalling the original valves. And most people will certainly lap valves when installing a brand new one of if the seats have been cut. Who is right here? And does it even matter what you do?
Valves only need to be lapped if there is no valve job done, or if a valve is being replaced without anything being machined to match.
I look at it like when you install new rotors and pads or piston rings. Yes they are new, but they are not matched or worn to each other. Just my .02
The reason you hear about it so often is because we seem to be in a day where budget rebuilding is common. People seem to be ok with lapping valves instead of having a machine shop do a proper valve job.
One problem with lapping valves is the compound. I have had a set of heads I could see light through one side of the intake valves. I lapped them and it showed a consistant, even mark around the entire seating area of the valve and seat. It's because the compound takes up space.
Proper machining and dye takes up no space.
If one wanted to compare it to brakes or rings let's also compare it to piston pins and bearings. Would you grind on those too.... Why not? Why not lap the guides?
Well because you don't want to create an abnormal wear pattern. Valves basically hammer the seats. Lapping doesn't replicate that action.
Dont use the crap you find in an auto parts store or Ebay etc. That stuff is waaaay too course and gritty (even the side marked fine if it offers both which some do)
I check the seal of every valvejob I ship....16 on a pair of heads. With a Newen CNC seat and guide machine they are almost always spot on but it also depends on how well the pilot fits the guide also
In fact I have about 10 carbide pilots from that move up in .0002 increments (four decimal places.....two ten thousandths of an inch between them). Getting the right fit helps improve seat concentricity.
All that said and knowing your machine and the correct speeds and feeds you occasionally get one that is just a smidge from perfection.....it happens.
In that case I use 400 grit lapping compound from Goodson to make a perfect seal and still the the surface finish of the seat itself in excellent condition.
This stuff is amazing.....without having any "grit" you can feel it can still work effectively on a hardened seat and leaves the very narrow seat angle crisp and smooth with a light gray color to it after its lapped.
If you need more than this to get a seat leak free than you should simply touch up the valvejob in that one hole instead.
Grinder brings up a good point about the LS7 Ti valves (or any aftermarket Ti valves that are coated). You cant lap a coated valve. In this situation I check seat concentricity/seal using a steel valve in the same size as the Ti valve meant to be installed in it.
If there is a slight issue with the seat concentricity in a valve seat meant for a Ti valve, then I lap that seat using a steel valve of the same size (I have boxes of different size lapping valves....use them once and then reface on my valve grinder so its perfectly true for the next seat that might need a slight tune up)
My collection of lapping valves.....LOL I have at least a dozen in each box so I can go awhile before having to reface them
This is one of those things Im convinced most other cylinder heads shops do not do. Literally check (and correct if need be) every seat in your set of heads before sliding them in a box.
I will tell you right now that NO production shop does this.....Im talking about Dart, AFR, TFS, Brodix, Texas Speed etc etc.
Not a chance.....only a really high end specialty shop is going to take the time to check seat concentricity on every set of heads they ship I assure you.
Guys that know me know Im a perfectionist and take great pride in everything I ship out with my name on it.
Anyway.....just wanted to pass along some very important info regarding the lapping situation.
Don't just use any lapping compound.....you will do more harm than good with the over the counter crap out there
Hope this helps....catch you guys later!
-Tony
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
If your working with modern (typically harder) valve seat inserts, I feel 400 is the happy compromise of cutting (without spending a bunch of time) and still leaving a really nice surface finish.
Goodson offers 800 grit as well but the 400 really is the "not too hot / not too cold" solution here IMO
Regards,
Tony
Seating pattern was checked from the witness mark made from tapping the valve into the seat repeatedly by hand
Then we vacuum checked the assembled head from exhaust and intake ports to ensure the valves were sealing properly on the seats.
No lapping done
