New cam suggestions l76
Old May 18, 2023 | 11:42 AM
Guy with a Chevy's Avatar
Default New cam suggestions l76
Cam and lifter that's currently stuck in the bore are ruined I can visibly see the cam lobe chewed up. Don't have the cam out yet need to order another balancer puller. My head's currently have .570 lift springs I would like to use them hopefully it gives me some good options? I'm looking for something like truck norris but not in the 500 dollar range. I know nearly next to nothing when it comes to the specs could someone help me pick out a new cam?
Old May 18, 2023 | 12:26 PM
Where do you want your power curve?
What are your current cam specs?
Old May 18, 2023 | 12:44 PM
I was running an ls7 cam and I'm looking for low end torque but want it to be mean all through the power band
Old May 18, 2023 | 01:08 PM
Almost anything would be an improvement on the LS7. It has a super wide LSA that kills power almost everywhere.
There is no do-it-all cam, but if you want a very versatile cam that would be an improvement on the LS7 cam, try the Summit 8701R1 (218/227, .522/.524, 112+2) or for a bit more but still well behaved, the famed Summit Ghost cam 8715R1 (222/234, .600/.575, 115+3) but the latter will need a bit more spring than you have now.
Best part is any of these cams are just under $300.
211/230, .558/.558, 121 are the LS7 cam specs for comparison.
Old May 18, 2023 | 03:09 PM
How does the 8713r1 with 222/232 112+5 .550 lift on both valves compare to those? It states it's a "stage 3" truck cam
Old May 18, 2023 | 05:18 PM
That'll be a strong cam, but a little rougher at lowest speeds. The Ghost cam is a bit smoother and possibly a bit stronger under the curve in the lower ranges due to the wider LSA
Old May 19, 2023 | 11:21 AM
vegas_ss's Avatar
Check with Cam Motion and fill out their form, they are pretty good and will have all the characteristics you are looking for in their recommendation.
Cam Motion Camshaft Recommendation Form
Old May 19, 2023 | 09:58 PM
I'm not gonna lie since I'm on a budget at the moment I ordered another ls7 cam for 80 bucks with shipping with plans to replace it in the near future so I could also avoid retuning right now. I've tried to get it into a few shops here near Corpus Christi, Tx for a professional rebuild everyone is backed up so I'm doing what I can with it with it in the truck I don't have access to a lift and I rather not rebuild one at my current residence. I ordered the cam today after removing the bad cam that held 3 chewed lobes and the journals still healthy and cam bearings babbit visually the same from 5k ago. After that the 2 lifters that got tight and held themselves in the bore I fished out with a 1oz neodymium taped to a piece of wood after giving them a tap to release them into the cam shoot? I've read some people with luck replace cam and lifters and no problems after I assume with a thorough cleaning. I could make a decent air/diesel jet to spray out the inside of the engine I will be dropping the pan if it's not too hard the windage tray as well. I'm being really hopeful here.
Old May 27, 2023 | 09:09 PM
Used ebay cam showed up held a nice gloss compared to the one I put in. Seams everything is in order for now hopefully this link works
