Lifter differences on the dyno
Old Jun 15, 2023 | 12:20 PM
BCNUL8R's Avatar
Originally Posted by G Atsma
What he's telling you is that's the only way rockers make a real HP difference. Ratio. that's it.
Same for heads. He gets questions like, "what's the better head, X or Y??" He will show WHY head X with the small ports and chambers can be better than larger, better flowing ports and larger lower compression chambers.
You need to look at context.
Nah that wasn’t his claim. You need to see the video titles and claims before you defend your heroes. His claim about heads said nothing about combustion chamber size or compression ratio only x head was better. His claim was roller tip rockers make more power period while ignoring any possible effect of the rocker ratio. He misleads with click bait titles.
Old Jun 15, 2023 | 01:35 PM
I always watch the whole video. Sometimes the title is a bit misleading, but overall they deliver sound info.
Old Jun 15, 2023 | 01:52 PM
BCNUL8R's Avatar
Nah any kind of sound scientific test would only have a single variable at a time. Nearly impossible for the average Joe without the resources, but with those resources and the clip bait thread titles I’ve seen enough to know his results are misleading to the point it seems he often has an agenda and manipulated the test to give the desired results so I no longer watch his videos.
Old Jun 15, 2023 | 03:59 PM
He has no agenda, as he has no corporate sponsors. Usually he just works with what he has or can get.
He has no reason to skew any tests as there's nothing in it for him to gain by it.
Some tests are combos of previous tests on different engines, but he is careful to point out differences that affect the outcome, yet emphasize what the intended focus is.
A true apples to apples test isn't always feasible under the parameters he works under.
He doesn't do clickbait, or desire results different than those that result. He has no reason for either.
Old Jun 16, 2023 | 05:26 PM
grinder11's Avatar
I agree. I don't like some of what he does, like comparing .010" plug gaps against .100" plug gaps, etc. But he does offer some good tangible results on many things. A roller fulcrum, roller tipped rocker does offer a power increase thru reduced friction, over a ball and socket, non roller tipped rocker, like the SBC. But it's not gonna be something you'll where you'll feel a huge difference sotp. The test that comes to mind is the one that picked up 8-10hp, or 1hp/cylinder, virtually nothing.
Old Jun 16, 2023 | 05:44 PM
LS299S10's Avatar
Whats it called when Brian Nutter sends him Summit Pro LS cams for free?
Old Jun 16, 2023 | 06:17 PM
Test subjects. Once done, they get stored. Much later on he might sell them for $25 each. Yeah, he's really living high off Summit....
Old Jun 16, 2023 | 06:20 PM
LS299S10's Avatar
So you know him personally?
 Michael S. Palmer
Old Jun 16, 2023 | 10:55 PM
I agree. I don't like some of what he does, like comparing .010" plug gaps against .100" plug gaps, etc. .
He did that in answer to a lot of "what if " questions put to him at different times.
Old Jun 17, 2023 | 06:34 AM
LS299S10's Avatar
Of course not, ********, just observant. He has covered that subject on his nightly live chats.
You don't get out much, do ya??
By get out much you mean stay at home and watch Richard Holdner videos?
Old Jun 17, 2023 | 10:24 AM
LS299S10's Avatar
Not like you. Only late evenings....
So you're the one that's been looking in my bedroom window.
Old Jun 17, 2023 | 11:32 AM
  #32
Cool it guys, or you both get a vacation.
Old Jun 17, 2023 | 04:43 PM
  #33
MuhThugga's Avatar
Originally Posted by LS299S10
If lifters are going to cause a loss it's going to be at the low end. There's more time to bleed down when things are happening slower.
Ever think about pushrods? The dyno hero of everyone here did a test on different length pushrods and found that longer makes more power up top. It's because oil in the lifter is more likely to be aeriated at high rpm. Longer pushrod leaves less space for oil.
I had a conversation with Brian Nutter, the engineer for Summit Pro LS cams and he was telling me how dirt track racers figured this out long ago. And since they are under strict rules and engine inspections someone figured out to put spacers in the stock lifters to take up some of the volume, and it did lead to power gains in the high rpm areas.
You're effectively achieving the same concept behind short travel lifters. Keep the oil cushion low and gain stability in the higher RPMs. That's really the only area I can think of where you could gain something switching between hydraulic roller lifters. How much of a gain is hard to say because it would depend on how much of a stability problem you are currently having.
